I design Amplifier with current feedback topology ,by this topology I can't use mode balance differential input and now I looking for very low noise balance to unbalance converter if any body have solution pls help
#2 |
very low noise balance to unbalance converter = transformer
#3 |
Good tranformer it very so expensive
#4 |
It's either a transformer, or SSM2142. A good transformer is better for S/N. A cheap transformer will sound bad.
-Chris |
#5 |
A ssm2142 turns a single ended signal into a balanced one. He wants the opposite.
See the TI's INA134.
Ben. |
#6 |
Hi ben,
Sorry, then SSM2141 or SSM2143. Different gain. -Chris |
#7 |
what happened to connecting one side of the balanced output to ground. wouldn't this be the lowest noise solution?
#8 |
Hi chrisr,
That depends. Many sources are active these days. Grounding one side would create lot's of distortion and crosstalk. If the other end were transformer coupled then, maybe. You would eliminate the noise cancellation that is one of the big benefits of balanced lines. -Chris |
#9 |
The subject is balanced to unbalanced? If noise cancelling is wanted it is the receiving end that needs to be differential. The sending end is of less importance. Please, take o look at www.jensen-transformers.com/an/an003.pdf .
#10 |
If you want some good quality transformers at flea market prices, look around for some old Altec/Peerless 15335As. I've seen them on eBay for less than $10. These are a 1:1 15k:15k bridging transformer and of very good quality.
If you can't find any or it's still not cheap enough for you, just make a simple XLR to RCA adaptor cable. Center pin of RCA to XLR pin 2 (or 3 depending how it's wired for positive versus negative) and the ground of the RCA to XLR pin 1. If you're using a shielded cable, terminate the shield only at pin 1 on the XLR end. Done deal. No chips. No power supplies. No hassle. se |
| Cyrus Pre - Unbalance volume | MAT124 | Solid State | 15 | 6th January 2012 12:12 AM |
| Unbalance Collector Emitter voltage both pnp and npn | EMX_125 | Solid State | 1 | 18th May 2010 03:30 PM |
| Looking for unbalance microphone pre amp | senee | Solid State | 1 | 30th January 2008 09:51 PM |
| How to convert Unbalance -> Balance Input ? | Minh | Solid State | 21 | 19th September 2002 11:09 AM |
| Balance control | 2Bak | Pass Labs | 4 | 11th July 2002 07:07 AM |
| Page generated in 0.08763 seconds (77.64% PHP - 22.36% MySQL) with 10 queries |
