Adcom GFA-555II problem - diyAudio
Old 9th November 2005, 02:11 PM   #1
Default Adcom GFA-555II problem
Hello all,
I have a 555II with a ground problem. The amp is overheating,when I measured the bias voltage it was extremly high on both channels. I tried to lower it but had no success. Then I measured the ground at the RCAs and nothing. I solder a temporary cable to the RCAs ring and grounded it and the problem was fixed but this is obviously not the right way to do it. I like to know if anybody around here has had this problem and if so what's causing the problem. I do have the service manual.
Thanks to all.
Old 10th November 2005, 01:02 AM   #2
anatech is online now anatech  Canada
anatech's Avatar
Hi oscarav098,
Check R104 / R154. They are 100 ohms from the signal common to ground. They may go open if a differential voltage appears between the inputs and chassis ground.
Replace with the same parts. Carbon film is original, you can use metal film if you want.
-Chris
Old 10th November 2005, 03:47 PM   #3
Default Thanks
I'll check them today and replace if they're bad.
Adcom GFA-555II badfireguy Solid State 8 1st March 2012 05:02 AM
Adcom GFA-555II the apostate Solid State 32 2nd September 2011 08:41 AM
Adcom GFA-555II with DC Offset sjdemark Solid State 19 28th February 2009 01:33 PM
Problem with Adcom GFP-555II claiborne Solid State 2 22nd April 2008 05:50 PM
Adcom GFA-555II PS for sale oscarav098 Swap Meet 2 3rd December 2005 02:03 PM
Copyright 1999-2017 diyAudio
