Old 9th November 2005, 07:33 AM   #1
opor is offline opor  Thailand
Default need amp for PSU +/-70VDC
Hello,
I have PSU +/-70VDC 1.4KVA and many Toshiba power out put device,2SA1943/2SC5200. I am looking for good dual chanel amplifier for my PA system.
Please advise.
Thank you
Old 9th November 2005, 08:02 AM   #2
quasi is offline quasi  Australia
quasi's Avatar
Default Re: need amp for PSU +/-70VDC
Originally posted by opor
Hello,
Please advise.
Thank you
Go to Google and search for "Studio 350" Follow the first two links.
By all accounts this amp is excellent. Your transistors are not as strong as the ones in the article so you will need to run extra in parallel. No changes are required for the rest of the cct and you could even use the existing layouts.
Cheers
Old 9th November 2005, 08:27 AM   #3
Very nice kit, Quasi...
Old 9th November 2005, 07:58 PM   #4
Default 2sa1943 on high voltage rails
Hi Opor,
I concur with quasi, 2sa1943/c5200 are not too good at higher voltages.
I did some numbers for ClassA Leach thread which gave
Some calcs gave the following
4 pairs MJL21193/4 running on 70degC sink can drive 100W into 8ohms (Tc max=92degC). Similarly 8 pairs 2sa1943/c5200.
If you want to run 6 pairs 2sa1943/5200 the sink must be kept down to 55degC (Tc max=75degC).
If you run +-70Vdc rails the SOAR problem gets even worse.
Multiple pairs will substantially overcome the fragility problem but then starts to get in the road of clean signal processing according to some contributors.
regards Andrew T.
Old 9th November 2005, 11:29 PM   #5
Have a look at this :
http://users.otenet.gr/~athsam/power_amp_300w.htm
I happen to have pcb for it.
Old 10th November 2005, 03:47 PM   #6
BlacK_Chicken's Avatar
Default 300W amp PCB
Hello
If you happen to have a PCB for this amp, wich I do search for a long time now. Could you please share it with me??
Thank you very much!
Greetings
Caps Needed, 20Kuf @ 70vdc 2" x 4" Zero Cool Swap Meet 4 7th December 2006 03:41 AM
enjoythemusic's t-rex amp: where is the +70VDC tap? jarthel Tubes / Valves 2 25th September 2006 10:37 PM
Where 2 Buy +/- 70VDC Switching PSU?? Zero Cool Chip Amps 2 18th February 2005 08:19 AM
Page generated in 0.08281 seconds (75.27% PHP - 24.73% MySQL) with 10 queries
