Could you please confirm that grounds should be connected like this as shown...
Thanks regards Leander |
#2 |
Did it Himself
Yes that should be good. Remember the speaker ground returns to the star point as well, not the PCB. Signal input leads to the PCB should be insulated from the chassis.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
its better to connect the GND from C12 directly to C13. You can also omit R23 and C10. |
#4 |
Ground from snubber ( Boucherot ) you must lead separately, not by common wire with filtration...
#5 | |
Mike |
#6 | |
And if r23 is used, this signal gnd should not be further connected to the power gnd. Mike |
#7 |
Hi Leander
With only two diode drops ( D2 an D3 ) you will have severe crossover distortion. You must add one or two more diodes and a trimmer pot for adjustment .
Jorge |
#8 |
Jorge, that's a CFP outputstage, it does not that high voltage to have bias ! With 4 diodes it will fry. But you're right, it's ClassB, and rod designed that thing for subwoofer.
Mike |
#9 |
Good Day,
Is it fine to connect the entire circuit common(star point ground) to earth ground of the power cable? |
#10 |
Did it Himself
Yes and that would be a good idea for safety.
| Isolating L and R grounds??? | wrestlinguy | Parts | 5 | 13th June 2006 03:50 PM |
| Multiple Grounds | Wynand | Chip Amps | 12 | 4th December 2005 11:38 AM |
| Why do we connect channel grounds together? | wes-ninja250 | Chip Amps | 12 | 30th October 2005 12:54 AM |
| PSU sharing grounds | neutron7 | Parts | 2 | 5th March 2005 12:23 AM |
| Transformers and grounds | soundNERD | Chip Amps | 21 | 18th February 2004 01:10 PM |
| Page generated in 0.09532 seconds (78.12% PHP - 21.88% MySQL) with 11 queries |
