Hello
I had days searching on the forum-search, I have found a lot but nothing completely satisfying. I am searching for a simple poweramplifierprojekt that is stable at a voltage of +-48V. Singlesided Pcb-layouts should be availeble. Power is is limeted with the supply voltage, somthing about 100W into 8ohm should be Ok, more or less is no problem. So, if someone has designed a small amplifier like this for himself and wants to share it, please feel free to do it! Thank you very much for your answers ! Though this might be a question which has been discussed many times. greetings Black |
#2 |
Hello
I'm still searching, aftel all I noticed that the red Circuits-desing needs a preamplifier I decided to search again. Please give me some advice wich projekts, apart from the leach amp are suitable, any power rating, either with or without PCB. Thanks a lot! Black |
#3 |
I could only help you with a design suitable with +/- 36v...
![]() Mike |
#4 | |
I wouldnt start with letting power supply decide what amplifier to build.
Here is a nice project, well documented with schematics, PCB and building description. I think very few of us would be disappointed with this DIY amplifier project. Quote:
#5 |
My 200W/4 class AB MOSFET amp.
If MOSFET is not what you want, it should be quite easy to turn his amp into a BJT output. Another one: My first solid state amp I would probably build that but with MJL4281/4302 output transistors. You could also use Marcus's M250 amp on 48V rails, you would just get a little less power. Same for amps rated for 55v rails or so, even the Leach should work at 48V. |
#6 |
Account Disabled
Hi Black Chicken,
If you're putting in the effort to build a power supply, provide heatsinks, and house the lot, why not build something a good measure above the average - Simple Killer Amp! Or check out my website - http://members.dodo.com.au/~gregball/guru_004.htm This has been hailed as the first really new design in decades! It's fully complementary to minimise high order distortions and will get you more power and sheer performance from your given power supply. That's why it's Patent Pending. Cheers, Greg |
#7 |
Hello,
This is not my first power amplifier or electronik work at all. I built a poweramp about two years ago, it worked really well at +-30V, than I started building a enclosure and a Powersupply for the amp that was constructed for +-50V, so I went for +-48V with big caps and good parts. But then The amp started to get instable at 48V one Worked, one not.....I never got this one to work at +-48V. So now I'm searching a Amp-design to finish the amp and to use the expensive Parts left over by the old design (enclosure, transformer) --------- The 25W amp looks really good, I do like these designs a lot, thank you very much for the link, maybe I'll build it in the future, just for fun. -------- Yeah the symasym is a great design too, but I do need something to cope with 50V, though I dont really need the Power giver through the voltage. -------- Jaycee: nice shematics, wich one Is more reliable in the buil, has one of them been build already succesfully? Wich of these do you prefer? I'd like to try the Mosfet-Build with 1 Pair of IRFP240/9240, because I dont need the RMS power all the time (home listenig, not PA use) Do I need to Change something? Is the amp able to drive these fets? thank you very much. ------------- Guru: also great designs, but living in Germany I am searching for a free projekt, thank you very much for your advice. any other suggestions are welcome! Black |
#8 |
If your looking for free then check this thread. You should read all of the thread, especially the last half as this will provide some understanding of the circuitry. Some have been built by members here already (including my self). General feedback so far has been very good.
http://www.diyaudio.com/forums/showt...551#post781551 Cheers
http://sites.google.com/site/quasisdiyaudiosite/ |
#9 |
Yes I did already read your thread, but I wasnt sure If the amp woul work at this low Voltage?! Is it still reliable at the lower supplyvoltage?
Another design I found on the Web, is on the attachment, what about it, are there any drawbacks, apart from not having a short circuit Protection? Thank you very much! |
#10 |
I cant see how this design can deliver 100 watts into 8 ohms with the voltage rails it specifies. Even if it could by using higher rails the output transistors specified would blow.
If you use my circuit with 50 volt rails you should; - change R6 to 12K (this leaves enough voltage for T4) - change R17 to 27K (less gain) - change T1 & T2 to BC546 (these are more common and cheaper) - use one less FET per rail. You will have an amp module that delivers about 110 watts into 8 ohms and around 190 watts into 4 ohms depending on the quality of your power supply. There is no short circuit protection offered by my design either (not yet anyway). Cheers
| TL projekt idea | Vigo | Multi-Way | 41 | 6th January 2010 09:07 PM |
| searching a ESX Q 275.2 or 175.2 | pit bull | Car Audio | 1 | 7th December 2008 08:46 PM |
| Searching... | Cortez | Forum Problems | 1 | 27th April 2006 12:23 AM |
| Added new projekt in wiki | hanskrj | Multi-Way | 1 | 23rd January 2004 06:27 AM |
| Searching for this guy | Guss | The Lounge | 1 | 3rd August 2003 11:04 PM |
| Page generated in 0.11572 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
