need a sub for an IC
Old 3rd November 2005, 01:27 AM   #1
Jim Karr is offline Jim Karr  United States
Unhappy need a sub for an IC
I own a Crown DC-300A amplifier which I dearly love. I need help.
There is one and only one IC in the entire amp....a dual op-amp in the negative feedback loop....UA 739. I replaced it this spring because one channel began fading away in volume, and exhibited a hissy, weak signal.
I ordered a replacement from Crown, (only place I could find one) and they nailed me $18 for a 14-pin DIP chip.
Well, my amp must have an incorrect voltage, since the chip is apparently failing again. However, I can't find this chip anywhere in stock by a parts distributor. Many websites for chip importers list the number, but then you've got to buy hundreds or thousands of them.
MCM in Ohio showed that ECG725 was a sub, but it's no longer available.
Are there any other subs that you can suggest? HELP!!!!!!!!!!!!!!
As for me and my household, we shall serve the Lord. Joshua
Old 3rd November 2005, 04:27 AM   #2
jaycee is offline jaycee  United Kingdom
http://pdf.alldatasheet.net/datashee...ILD/UA739.html
You could probably replace it with any dual opamp provided the replacement isn't too fast
Old 3rd November 2005, 12:00 PM   #3
This sounds wonderful........any suggestions as to which opamps would be appropriate?
(Thanks kindly for your response)
Old 3rd November 2005, 02:11 PM   #4
paulb is offline paulb  Canada
A bit tricky - not too many dual opamps come in 14-pin DIP package.
I see it here:
http://www.americanmicrosemi.com
Check the datasheet from the previous post to figure out which one you need. I think plastic is probably ok.
Old 3rd November 2005, 04:47 PM   #5
As the legendary Harry Caray used to bellow,"Holy Cow!" 66 cents is a whole lot cheaper than 18 dollars from Crown! Thanks!
need a sub for an ICHide this!Advertise here!
Copyright ©1999-2017 diyAudio
