Old 2nd November 2005, 02:38 PM   #1
nathank is offline nathank  United States
Default Need help diagnosing plate amp.
Hello all, I found the site last night, and I have been enjoying hours of reading. Looks to be many very knowledgeable people here.
I was wondering if you all could offer me some assistance with an Infinity sub problem. It is a BU80 sub that has a 8" driver and 75wRMS plate amp. Nothing big but it fills the bottom in everyday situations.
When turned on and connected it has output through the speaker, somewhat of a crunching sound. No noticeable real sound, just the static crunching. It was connected low level, I tried new low level cables, new low level source from a different receiver, and high level connections with the same result, just the same crunching. I pulled the driver and connected it to another amp and it worked fine.
The board on the plate amp shows no visible burn areas, everything looks normal. I have been looking everywhere online for a schematic and can't find anything.
Could anyone offer me a starting point with this repair? This has been something I really wanted to learn, but I really don't know where to begin.
Old 2nd November 2005, 02:55 PM   #2
Did it Himself
richie00boy's Avatar
My first guess would be a dodgy output or driver transistor, or dry joint around those devices.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 2nd November 2005, 04:53 PM   #3
One more additional spec of info. The sub actually belongs to my parents. When I went to their house to help them out with it, I noticed it was plugged directly into a wall outlet, with no surge protection.
Old 2nd November 2005, 04:59 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi nathank,
Also check that the woofer moves smoothly in & out. Bad joints are a good start. Pay attention to heavy components, and where parts are attached to things like a heatsink.
-Chris
Old 2nd November 2005, 06:26 PM   #5
Originally posted by anatech
Hi nathank,
-Chris
I am 99% sure it doesn't have anything to do with the driver. I tested it on another amp and it worked perfectly.
Old 2nd November 2005, 06:37 PM   #6
anatech's Avatar
Good, so it sounds like cracked connections.
-Chris
Old 2nd November 2005, 07:29 PM   #7
Is there anyway to check the transistors on the board? or do they have to be removed?
I found this:
http://sound.westhost.com/troubleshooting.htm#tests
with a transistor quick check.
Old 2nd November 2005, 07:47 PM   #8
anatech's Avatar
First try to resolder the leads carefully. You don't have shorted transistors or the fuses would blow. In circuit transistor tests in this instance are not going to help you.
In circuit tests are okay for checking a transistor junction, depending on the circuit. They can detect shorts, depending on the circuit.
-Chris
Help diagnosing phase-splitter pilli Tubes / Valves 13 5th July 2008 02:53 PM
diagnosing mains hum baldy Solid State 3 17th October 2007 01:16 PM
Diagnosing heat-related problem with amp valterdaw Car Audio 3 9th May 2007 03:16 AM
Help diagnosing noise dsavitsk Tubes / Valves 7 4th January 2007 01:26 PM
Help diagnosing subwoofer amp bkspero Solid State 22 1st November 2006 02:31 AM
Page generated in 0.09161 seconds (78.66% PHP - 21.34% MySQL) with 10 queries
