The OPA-2134 is a very good OP Amp that works well with a +5V supply. Currently this part is hard to buy (in SO-8).
Can anyone suggest a similar part? It needs to work with a 5V supply but does not need to be rail-to-rail (the OPA-2143 is not rail-to-rail). Ideally it should have low noise and reasonable bandwidth. |
#2 |
would the OPA2132U work for you? it is pricier but is in stock at Digikey
#3 |
What about the OPA(2)343/(2)353?
#4 |
Thank you for the suggestions.
The OPA2132U or UA will certainly work but it is expensive for my application. The OPA2353, like most CMOS rail to rail parts has excessive 1/f noise. I think the AD8606 or newer AD8656 is probably a better choice for low voltage rail to rail requirements. There are very few op amps that will give good performance with a 5V supply (and none to my knowledge that work great). The OPA2132 looks fairly good on paper. I use this part for antiimagining filters for D/A. In general, you want a Gain-Bandwidth Product of at least 100x the sample rate for this situation. |
#5 |
Hmm... is bipolar input OK? if OPA2132 is too expensive then perhaps you could use MC33178, <$1 at Digikey. Output is spec'd at +/- 2.5V rails, 600ohm load. En about the same, In higher due to bipolar input but pretty good at 0.15pA/rtHz @ 1kHz, noise Req of 50k. SR and GBW are lower though, guaranteed minimum of 1.2V/us, 2.5MHz may not be good enough for you.
NJM2115 is even cheaper at less than $0.20 at Mouser (unfortunately only DIP is in stock), output also spec'd at +/- 2.5V, 2k load, typical 4V/us, 12MHz. Input noise appears similar to MC33178. |
#6 |
TI TLV2362 is similar to NJM2115 and about 1/3 the cost of OPA2134 at Digikey, LMV721 is similar at higher cost.
#7 |
I am familiar with the MC33178. I think Cirrus (back when they were Crystal), used them in some of their reference designs.
I wish they were a little higher bandwidth. I may have to take a closer look at this part. Does anyone have any experience with it? The LMV721 is not available in SO-8 The TLV2362 is somewhat noisy at low frequency and seem to have a lot of THD. I haven't ever tried this part. Thanks for the suggestions. |
#8 |
LMV722 is dual version of LMV721, available in SO-8, cost about 80% of OPA2134.
MC33077 is a wider bandwidth version of MC33178 with lower THD curves and higher Ib, In, datasheet curves show output swing at +/-2.5V, 2k load. MC33078 bandwidth is inbetween, similar THD to MC33077, no +/-2.5V data, is used in Lynxone, its 1kHz loopback THD is less than 0.003%. TLV2362 and OPA2132 datasheets have similar En curves. TLV2362 THD curves are higher than OPA2132 but lower than MC33178 and are taken at +/-2.5V rails. Looks like you have some research and evaluation to do. |
#9 |
have tried the MC33078 (though from TI) and it worked fine at 6V.
#10 |
I want to thank everyone for their comments.
I still like the OPA2134 best, but I think I need to evaluate a few new parts. Life is so much easier when you have higher (and bipolar) power supply rails. Al Clark |
| AB2 Anyone else done similiar | richwalters | Tubes / Valves | 2 | 17th June 2008 08:11 AM |
| dont need a DEQX, but want something similiar | MotoMan_Yz400 | Digital Source | 4 | 13th March 2008 06:57 PM |
| Is there any better OP than OPA2134 | Progg70 | Solid State | 95 | 15th March 2007 07:15 PM |
| what to do with OPA2134? | kmj | Chip Amps | 3 | 12th January 2005 08:38 PM |
| Infineon BTS5215 and similiar IC's | peranders | Parts | 3 | 19th June 2004 08:55 PM |
| Page generated in 0.09560 seconds (80.29% PHP - 19.71% MySQL) with 10 queries |
