Old 31st October 2005, 02:16 PM   #1
Kevinbd is offline Kevinbd  United Kingdom
Default How much CM range does a differential need?
Hello,
Just wondering if you can help me with something. How much common mode range (voltage) does a differential need in a power amplifer ?
In other words, what is the minimum voltage I can feed the input stage with (say a Doug. Self type amp) ? Headroom I guess?
Thanks for any help
Kevin
Old 31st October 2005, 02:19 PM   #2
darkfenriz's Avatar
input sensivity/feedback factor
for full power, as far as I understand what you mean.
Old 31st October 2005, 09:07 PM   #3
Default What I mean't was.....
What is the minimum headroom the LTP (differential needs) on it's emitters.
Can I feed a CCS at 12v with a battery? giving around 10v headroom for the LTP.
kev
Old 31st October 2005, 11:08 PM   #4
Account Disabled
Hi Kevinbd,
I can answer this. Input sensitivity, as Darkfenriz has stated, is the voltage modulation on the input stage and is typically 1-2 Vrms for full output so +/- 3V of modulation about zero. Now for your tail supplies, if you want some introduced even harmonic distortion, you can use tail resistors from as low as 6.1V zener supplies for simplicity and best decoupling from the main supply (LOW Z zener). And you could expect around 0.2% THD.
However, if you don't want distortion due to current or voltage modulation and wish to use current sources, 12V should be plenty to ensure clean operation.
Greg
Old 1st November 2005, 03:12 AM   #5
Helllo amplifierguru,
Thanks for your reply.
Your answer leads me on to another question. If the LTP has very high input sensitivity (say a Zin of 150K+, maybe a couple of uA of base current) suitable for some low level sources, can the headroom be reduced ?
Old 1st November 2005, 03:38 AM   #6
Account Disabled
Hi Kevinbd,
You can reduce the input stage supply rails to the point where -
Vs = Vin for full output (pk) + Vccs min for operation. This maybe 2-5V depending... but getting a bit compromising.
Greg
Page generated in 0.07529 seconds (72.09% PHP - 27.91% MySQL) with 10 queries
