Old 30th October 2005, 08:34 PM   #1
anatech is offline anatech  Canada
anatech's Avatar
Question audiolab 8000d bias
Hi all,
I am repairing an Audiolab 8000d that has been worked on by another shop. At this point I'm having trouble setting the bias. The Vb-e voltages on the output stage reduce as the voltage increases and is below the value calculated from the current flow through the driver emitter resistors. The protection circuit has had it's components pulled, as well as the reversed biased diodes from output to supplies.
At this point I am working from an 8000a schematic. It's mostly close. I've pulled the TL071 DC servo, it's blown & I don't have another yet. DC offset is running around -60~70 mV. The diff. fet seems be be in good order.
Any hints would be welcome.
-Chris
Old 30th October 2005, 09:01 PM   #2
anatech's Avatar
I replaced the Motorola MPSA42 / 92 the other shop used with the Zetex equivalents from the protection circuit. The Motorola's when into the old Zetex locations.
At full line voltage I have low bias on that channel - but there is some bias (about 24mA) while the good channel is sitting at about 80mA.
What worries me is that the Vb-e on the repaired side comes up faster than the good side, goes down (good side keeps increasing smoothly) and finally come up to around 24mA. The DC offset without the servo is sitting at -4.2mV with AC line noise on it. (not bad) The good channel is sitting at +4.1mV with just broadband noise (expected).
Anyone familiar with this amp?
-Chris
Audiolab 8000a dantzig65 Solid State 9 6th June 2011 02:48 PM
Help! Audiolab 8000A Matthewong Solid State 9 15th October 2007 06:09 PM
Audiolab Monoblock jakobgp Solid State 0 3rd June 2006 06:20 PM
Audiolab diy guy Solid State 0 29th April 2005 08:39 AM
PC Audiolab AuroraB Everything Else 0 25th August 2001 06:53 PM
Page generated in 0.06660 seconds (69.12% PHP - 30.88% MySQL) with 10 queries
