Hello Everyone,
I am building one of Rod Elliott's P101 amps for two channel use and would like to use to separate toroidal trannies. Could someone please tell me what specs I should be looking for in each one. Rod recommends 70-0-70 and I am unsure if this is for single channel, since the PCB's are sold separately, or if this a total for two channels. If the 70-0-70 is reccommended for the two channel then would I get (2) @ 35-0-35?This is my first real project and just don't want to screw it up. Thanks for the help guys. David |
#2 |
Electrons are yellow and more is better!
I'm sure you can get some here also but Rod has his own support forum if you didn't know that.
http://sound.westhost.com/phpBB2/
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Did it Himself
The voltage is irrelevant to how many channels, it's simply what determines max output voltage. The current and VA rating are what differ when you have multiple channels. The ratings are on the ESP website.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
I am waiting for access to the secure portion of the site as we speak. I was forced to order the PCB's at my work due to PC vs Mac problems and I think I should expect to see the email from Rod on monday. Hopefully all will be apparent. : )
I have been doing some studying at the zero interference web site but most of this is over my head at the moment. From what I gather at ESP...........I will need (2) trannies that are in this range: AC Volts DC Volts VA Power (8 ohms) 50-0-50 +/-70V 300 240 And my only problem come from the following info available from AVEL. Load(VA) Sec Volt (V) Sec Cur (A) Reg (Typical) 330 45 + 45 3.67 6.0 I feel like I am missing some info to make a choice. Is this true? I don't see or understand the specs. Can I go larger or is this tranny too big for a single channel? Cheers, David |
#5 |
Oppppssss...........Zero Distortion : )
#6 |
I used a single 45-0-45 800VA tranformer for a three channel P101 and it is just fine. I'm not sure when you would ever need 200wpc, but if it is important a 50-0-50 500vA would be plenty for a stereo amp.
This transformer would be just right for a stereo P101. You could always use a dual bridge if you wanted but I'm not sure you would hear the difference. The power supply that rod suggests uses one trans and one bridge. Blessings, Terry |
#7 |
So Terry,
It is ok to exceed the 300 VA rating just not the recommended =/- 50VAC? From what little I know ..................I think I will be going with separate trannies and all of the tweaks mentioned on the zerodistortion web site for my power supply. Does this sound like a reasonable plan? I really am in the same spot you were in last year when you built your amp. The only tools I own are a good soldering iron and multi-meter. I am trying to get the same or better quality as some of the Krell and B&K amps I have auditioned at the high end audio stores in the area. God Bless, David |
#8 | |
If you really want to have a killer PSU use two of these. Blessings, Terry |
#9 |
Will (2) of these .....................
http://cgi.ebay.com/45-45V-700VA-Tor...QQcmdZViewItem .....................do the trick?
#10 |
Absolutely!
| FS ESP P101 Amp | john65b | Swap Meet | 3 | 26th February 2008 07:24 AM |
| SAE P101 won't switch off! | highviewvideo | Solid State | 0 | 29th August 2007 02:34 PM |
| Transistors for ESP P101 amp | Bama Slamma | Solid State | 1 | 7th July 2007 12:03 PM |
| esp p101 | djronbxs | Solid State | 2 | 6th January 2007 01:02 AM |
| Esp P101 Values | Flavio88 | Solid State | 2 | 30th August 2006 07:26 PM |
| Page generated in 0.10503 seconds (80.13% PHP - 19.87% MySQL) with 10 queries |
