Old 9th October 2002, 02:53 PM   #1
Send a message via ICQ to Christian
Default Keeping components close?
I'm designing a chip-amp, based on the LM3886 chip. Im building it on breadboard, so now I'm wondering if I should try to pack the components as close together as possible?
Will this reduce noise? And also, I don't think I need the 3-4extra components for the mute function, so should I just leave them out? And if you know of any other modification I'd be moste happy!
Beast Regards,
Christian V
Old 9th October 2002, 03:07 PM   #2
trwh is offline trwh  United Kingdom
trwh's Avatar
Hi Christian,
Packing the components close together can help with stability - I certainly wouldn't make any of the more critcial traces (feedback loop, etc.) longer than is absolutely necessary. Note that if you omit the components associated with the mute function, the chip will not come out of mute mode.
Check out my small PCB layout for a LM3876 based amp here:
http://headwize.powerpill.org/projec...rison2_prj.htm
Note also that Rod Elliott sells PCBs for the LM3876 (www.sound.au.com).
Hope this helps,
Tim.
Old 10th October 2002, 09:51 AM   #3
pinkmouse's Avatar
Hi Christian
Try this link, lots of useful info on chip amps
http://pub4.ezboard.com/ffakeidsfrm1
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 10th October 2002, 05:02 PM   #4
I did one chip board, don't know how it sounds yeat, but I really hope it won't be as noisy as my other LM3886 amp ( which was really noisy).
But as you can see, I packed things real tight.
Best Regards,
Chris V
Keeping cost down? Zap Tubes / Valves 7 14th July 2008 03:56 AM
Is this capacitor worth keeping? cadbury8 Parts 15 4th July 2007 04:44 PM
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 09:58 PM
Has anyone been keeping up on the 'New Sensor' Controversy? aletheian Tubes / Valves 19 21st December 2005 11:17 PM
Page generated in 0.07955 seconds (71.49% PHP - 28.51% MySQL) with 11 queries
