Old 27th October 2005, 02:33 PM   #1
Calebay is offline Calebay  Denmark
Default Amplifed Ear Dc on output
Hi
i build this thing you can see it here: i get about 0.68 volt DC on the output??! the Ac signal looks fine on the scope. from what i can see there must be a mistake in the last stage (Q4) or have i done something wrong? i like to know how i get rid of this DC
THXHere
Old 27th October 2005, 08:06 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Calebay,
This has a class A output stage in the oldest sense of the term. The DC current passes through the load (speaker or earphone). The amount of DC across the output is determined by the DC resistance of the load and the standing current in Q4. This will change a fair amount with temperature.
-Chris
Old 27th October 2005, 08:27 PM   #3
MikeB is offline MikeB  Germany
MikeB's Avatar
This DC-offset is by design... unavoidable without redesign.
Mike
Old 27th October 2005, 10:58 PM   #4
anatech's Avatar
Yes, and a coupling cap would break it.
Smile. It is what it is.
-Chris
Old 28th October 2005, 04:41 AM   #5
Send a message via Yahoo to johnthetweeker
Yeah, the headphone coil's DC resistance is the load resistance for the output transistor. We used to do such things in the valve lab those days.
John (not the baptist)
Old 28th October 2005, 09:25 PM   #6
Default Tnx
it works now i added a coupling cap and a resister..
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.07587 seconds (76.10% PHP - 23.90% MySQL) with 10 queries
