Old 27th October 2005, 01:17 PM   #1
Skorpio is offline Skorpio  Denmark
Default Unity gain NFB speaker-buffer
I want to try with a special buffer between my poweramp and the speaker, to isolate the feedback loop from the speaker load.
I have a trafo 18-0-18V/800VA and 2x47.000uF, + heavy heatsinking...
Now I need a circuit to use...do some of you have some experiences?
Old 27th October 2005, 05:31 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Yes.
Old 27th October 2005, 05:50 PM   #3
darkfenriz's Avatar
these circuit are called "power followers"
You'll find one in PMA'a webside, nice one.
I guess he meant this saying "yes".
Old 27th October 2005, 05:59 PM   #4
PMA's Avatar
Darkfenriz,
you are right. I prefer a little bit of self-confidence and creativity, for example to perform a search. I belive that it leads to better results than just following recommendations.
Old 28th October 2005, 09:22 AM   #5
djk is offline djk
djk's Avatar
This looks interesting, two versions, 'hot' and 'cool'.
http://www.audiodesignguide.com/my/Hot_Follower1.GIF
Full text:
http://www.audiodesignguide.com/my/index.html#MY_A
Old 28th October 2005, 01:06 PM   #6
Nice design PMA
But I don't like the output configuration, I prefer a standard darlington type.
Do you have any remarks to the termal stability this type in your circuit?
Old 28th October 2005, 01:11 PM   #7
Ultima Thule's Avatar
I guess you have 2 ch stereo amplifier... take the output of one channel and feed the other channels input through a resistor divider corresponding to the gain of your amplifier, done!
Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 28th October 2005, 01:13 PM   #8
Did it Himself
richie00boy's Avatar
I assume that you are wishing to use a non-global feedback power follower and some favourite main amp then? Or the exercise is pointless as the follower will be affected by the back EMF etc even worse (due to massive feedback) so the problem remains. In fact, instead of such a power follower, why don't you just make the main amp non-global feedback? This would be cheaper, easier, smaller, use less parts, less heat...
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 28th October 2005, 07:21 PM   #9
try http://www.altmann.haan.de/splif_page/ just up your street.
Global feedback to get the best out of your classAB power amp and a follower stage to drive the speakers. Even a guide on multiple followers if you want to have separate outputs for individual speakers. A cheap way to bi-amp your speakers, but not suitable for active speakers
regards Andrew T.
Old 30th October 2005, 08:31 AM   #10
mtlin12 is offline mtlin12  Taiwan
mtlin12's Avatar
Try this NFB Power Diamond Buffer ,
and some pictures are in DC adjustable double-Sziklai Power Diamond Buffer.
It has been tested with tube-pre & speakers and worked quite good for several months.
EuLeit Audio Studio one of the best hi-end Amp design house in Taiwan http://www.euleitaudio.com
Simple discrete unity gain buffer tcpip Solid State 111 7th June 2007 06:55 PM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 10:02 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 02:30 PM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 11:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
Page generated in 0.11064 seconds (80.57% PHP - 19.43% MySQL) with 10 queries
