#11 |
That's a bit complex to be simply called a 'diamond buffer', OTOH, the 'hot follower ' linked to above is a 'diamond buffer'.
#12 | |
Though I admit it is too complex for a normal DB, but if the supply voltage is not too high say 18-0-18, it can be much easier to take off the STAND-BY & Voltage Reference circuit and about 8 trannies. Because the 2SK246BL can sustain only 50V. Q8 through Q11 are for JFET source follower and bias provider, no gain, but the DC output level can be adjusted by tunning the SVR1. The circuit's thermal control is very easy.
EuLeit Audio Studio one of the best hi-end Amp design house in Taiwan http://www.euleitaudio.com |
| Simple discrete unity gain buffer | tcpip | Solid State | 111 | 7th June 2007 05:55 PM |
| Unity gain buffer in front of or behind TVC? | KT | Chip Amps | 9 | 26th March 2006 09:02 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Unity Gain Tube Buffer | AKSA | Tubes / Valves | 41 | 2nd January 2004 10:11 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
| Page generated in 0.06323 seconds (67.23% PHP - 32.77% MySQL) with 10 queries |
