I have noticed that many designs have a resistor with a very small resistance (about 0.1 - 0.33 ohms) in series with the speaker load and ground. What is the purpose of this resistor? I know it's there to prevent something but what? Oscillation, power loss on wire, ground loop, RF?
Where should this resistor be located circuit wise? Close to the signal ground point, close to the power ground point, close to the chassis ground point or close to the speaker load? I know several people have opinions about this. Thanks in advance. Teemu K |
#2 |
This resistor is not there on its own, rather is will normally carry a small inductor. The purpose of the inductor is to isolate the amp from capacitive loads for high frequencies and thus help stability. The resistor is there as a physical support and also to lower the lf resistance of the inductor wire.
BTW, if several people have an "opinion" on this, how are you going to chose the right one ? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 | ||
Hi Jan,
Teemu K |
#4 |
It doesn't quite fit your description of connection, but the values you mention makes me think you mean the emitter resistors (or source resistors) of the output transistors. If the output stage has emitter followers (or source followers), the transistors are usually connected to the output via small resistors on the order of 0.1 - 1 Ohm.
Do you have a link to some specific schematic with the resistors you mean? |
#5 |
What you describe could be the sense resistor in a current feedback amplifier. But these are relatively rare. As Christer says, do you have a diagram?
Jan Didden
#6 |
I guess I saw one in a grouitar amplifier, probably to lower damping as tubes have (pathetic isn't it). Otherwise it could be just a 'model' of cable resistance or something? Or current sensing like Jan mentioned.
just guessing regards |
#7 |
Here's few of them...
0.22 ohms in this one: http://www.mif.pg.gda.pl/homepages/tom/files/65W.gif 0.1 ohms in this: http://www.mif.pg.gda.pl/homepages/t...es/8240-61.pdf This one has a network of resistors: http://www.stlouismusic.com/download...CA/24701C4.PDF 0.1 ohms again: http://www.stlouismusic.com/download...+/20101H7_.PDF Teemu K |
#8 | |
if this is the case those transistors are added to insure thermal stability , as u should know , when transistors get hot the hfe increases also , without those resistors the current will rise and nothing will stop it .....eventually causing
if you are not living on the edge you are taking too much space |
#9 | |
Current feedback by its nature tends to keep the output current through the speaker constant even if the load impedance changes, so the amp works as a current source with a very high Zout. Damping is virtually non-existing, therefore sometimes this is combined with voltage feedback to get at least some form of damping. The last three using a combination of voltage and current feedback. The two last ones seem functionally equivalent. But, as I said, these are relatively rare. the vast majority of amps don't have this and use voltaedback from the output node. Jan Didden
#10 |
yes, all are guitar amps, because guitar speakers are preferably driven by tubes. Forget about it. It is not for Hi-fi, neither make your SS guitar amp sound tubey. I think so..
| Use board trace as a low value "resistor" | MJL21193 | Solid State | 25 | 7th October 2008 01:05 PM |
| DIY "speaker box" ("BOOM BOX"). Help needed. | MASantos | Full Range | 6 | 2nd September 2007 12:00 PM |
| 600 ohm resistor between "+" and "-" of balanced inputs. | skpb | Analog Line Level | 3 | 20th October 2006 12:38 PM |
| Anyone heard of "in-rush" limiter resistor | andy2 | Tubes / Valves | 14 | 31st March 2006 02:39 AM |
| Page generated in 0.11553 seconds (84.60% PHP - 15.40% MySQL) with 10 queries |
