Here i am, humble, and accepting that all my efforces result nothing related to have Graham return.
Also exercising the hability to forgive the ones that disturbed, and acepting that i "let them disturb me"...so....not only they are guilty, but i was guilty too, accepting to read and to answer, giving enougth room to them to disturb me... i was weak too. They installed batteries and i started to run...moved by remote control. Well, my need is some advise, as i am not an EE, all i have is practical experience, and that practical experience is saying to me that will be better to use many transformers. Explaining the idea: I will construct,...already started, a multi amplifier system, as i think that sending only small bandwith, adequate to tweeter, it will produce better sound (the capacitor already do this job)...but i am thinking about to produce "treble amplifier"..... high Mids amplifier, low mids and bass amplifiers and to bridge amplifiers to sub woofer. I am already in doubts about, what amplifier use for what....as i have many Aksas, 2 GEMS, 2 Symassym and will receive boards to make two Chip amplifiers, LM3775....or 3875, do not know....and people told me they are good for voices. But the PROBLEM is: I will produce different power amplifiers....they will have different output, based in musical sound composition.... the proportion of tones...so...treble will not need more than 15 percent of total power...when sub woffer will keep 60 percent of total power. The problem are the transformers....i have already done, prepared and well sized, transformers enougth to 9 channels, each transformer i made with double output coil...so...4 separated transformers are already done... each one of transformer output will be sent to separated rectifier and 5000uf each rail filtering.. having subwoofer power supply 15000uf each rail...those power rectifier and filter circuit boards are almost ready...needing only testing and some cleaning,.... will be 9 boards separated, one to each channel. The doubt is....i have a huge transformer, big enougth to supply all the amperes i need, and having room to be coiled with all those voltages i need.... 4 different simetrical output voltages...those 4 windings made twice, resulting in 8 separated windings...... with the inclusion of the high power subwoofer winding, they will constitute in 9 coils with diferent wires diameter. The question is: What sittuation may be better....only one transformer with many windings, or many transformers? In my mind...many transformers may be better...but i really have doubts. Please, take into your basis to analise, that both sittuations will provide the needed voltage and current.( some not real and ideal winding)... the interaction of consumption is something i am worrying about...my concern is the voltage interactions... When subwoffer will be draining more than 6 amperes average, will i have too big influence in others windings?.... is this sittuation worst than separated transformers? Can you help me?...... what do you think about?...have a better idea? regards, Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee |
#2 |
You could use one transformer with two secondaries and take advantage from different speaker impedances, SPLs and possible bridging amplifiers.
cheers |
#3 |
I will post 8 images, to show you the preparation...there you can see the transformer size, evaluating it by comparison with other parts that are near it.
regards, Carlos
#4 |
Here is:
regards, Carlos
#5 |
Here it is:
regards, Carlos
#6 |
Here is:
regards, Carlos
#7 |
Here is:
regards, Carlos
#8 |
Here is the one.
regards, Carlos
#9 |
here it is:
regards, Carlos
#10 |
Of course i can measure it.....but it seems to be around 1 Kilowatt!
regards, Carlos
| Griffin "27" Omega 3 Loudspeakers - Opinions? | izools | Multi-Way | 26 | 23rd November 2011 12:40 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| Opinions of the merits of "Tonsil" Drivers? | Brisso57 | Multi-Way | 1 | 21st August 2007 03:00 PM |
| TAS "Class D issue" -opinions. | The golden mean | Class D | 4 | 13th January 2007 11:27 PM |
| Page generated in 0.12190 seconds (76.75% PHP - 23.25% MySQL) with 11 queries |
