Rotel RB850 Still Current? Schematic Included - diyAudio
Old 8th October 2002, 06:58 PM   #1
Default Rotel RB850 Still Current? Schematic Included
I've got a Rotel RB850 amplifier, to which I made some small mods years ago (new Audioquest power cord, real binding posts and RCA jacks). The amp uses dual transformers and rectifiers. I have the schematic, what do the experts think, is this amp a good design or not? Is it worth upgrading some of the parts (I was thinking of input cap, feedback resistor, and 0.22 ohm emitter resistors in the output stage, and perhaps Schottky rectifiers if I can find the proper rating of what is in there now). Or is the design so old that it should be tossed into the basement system?
Thanks,
RonS
Old 8th October 2002, 08:50 PM   #2
raul_77 is offline raul_77  Europe
Besides the usual changes of compnents for better ones, you can add a 100uF capacitor across D602 (+) and R608 (GROUND).
I think than read R608 in the source current for the differential input.
This down the noise floor in the input, generated for the output in the supply, and the ressult are tath are show new information, and appear a 3D image. Almost magic.
But you need made before the other improvements for apreciate all this.
Happy days,
Raśl Couto
Old 8th October 2002, 08:59 PM   #3
Hi Raul,
Yes, D602+ is followed by D604 then R608 to ground, in the current source for the input differential pair. So I should bypass the entire string of D602 to R608 with on cap, 100uF, about 100V to be safe? And this will lower the noise floor? That's what I want, lower noise, more 3D magic
Anything else besides parts upgrades, and what parts would you upgrade? I was told that maybe C616, 5pF should be improved. What about a seperate regulated power supply for the input diff. pair, like the Ryan Adcom upgrade?
Thanks again,
RonS
Old 8th October 2002, 11:12 PM   #4
Default Regulator
The Adcom's Kit Ryan upgrade was for the whole amp, a high current regulator, not just for the first stages.
Carlos
Old 9th October 2002, 09:04 PM   #5
Hi RonS
The usual parts for upgrade are the capacitors.
For small values, less than 10nF, the best election are the Styroflex, or the Ceramic NPO.
For up to 1uF use polipropilene, or any film and foil: MkC, MKT. The series 470 from BC componennts (Philips) are a good election.
For higer values use low Z electrolitics. The minimun can be the Panasonic FO.
If you can, please, read the series of articles about "Sound of Capacitors" tath Mr Cyril Bateman have publised from this June, perhaps are the best work about capacitors tath have never writen.
The other upgrades: Schottkys, etc. are also a good idea.
Happy days,
Raśl Couto
Old 9th October 2002, 09:17 PM   #6
Sorry,
"Sound of Capacitors" are pubished in Electronics World & Wireless World.
Happy days,
Raśl Couto
Old 10th October 2002, 12:19 AM   #7
Default Rotel circuit
Am I wrong or there should be a connection point between Q612's collector and the trace that goes to Q618's base?
What does that star close to C616 mean? What do they say on the diagram?
Carlos
Old 10th October 2002, 01:07 AM   #8
Carlos,
I can't comment on the connection between Q612 and Q18, that's beyond my comprehension
As to C616, the star indicates that this part should be used everywhere in the world except for the UK. It's a 5pF cap. Any ideas about this one?
What do you think of the circuit in general, and the quality of the transistors themselves?
RonS
Old 10th October 2002, 01:13 AM   #9
Tube_Dude's Avatar
Default carlmart
Hei Carlmart!!
You are right, there should be a connection point between Q612's collector and the trace that goes to Q618's base...of course!!!
Jorge Santos
Old 11th October 2002, 06:18 AM   #10
Morello is offline Morello  Sweden
Send a message via ICQ to Morello
Default Re: carlmart
Originally posted by Tube_Dude
Hei Carlmart!!
Jorge Santos
Thers should not! The 5p-cap is HF-feedback.
Audio design engineer. Commerical amplifiers: O&G Engineering RS2000 and Holographic Audio AMP-27 among others.
Rotel RB850 transformer blown? rhiolly rub gt Solid State 5 16th April 2009 03:59 PM
Problem with Rotel RB850 rmsmax Solid State 21 27th January 2009 01:42 AM
Rotel rb850 Leisner Solid State 54 4th October 2007 09:28 PM
Current feedback amp, pcb files included Mark Hathaway Solid State 1 14th December 2003 07:42 AM
Copyright ©1999-2017 diyAudio
