I am having problems biasing my amp. What ever I try voltage drop across emitter resistors (R33 - R40) remain 0v if there is no signal at the input. This is what I am doing, pls correct me if i`m wrong: 1)Short signal input to ground 2)disconnect speaker from output 3)set the voltmeter to dc millivolts reading 4) Read voltage across one of the emmiter resistors (R33 - R40) 5) Vary R22 preset from maximum resistance to lower resistance Voltage across emmiter resistors does not vary and remain 0.000v . How is this prossible? Note: If a signal is given to the amp and a speaker is connected, it sounds good. |
#2 |
This is the amp
#3 |
here
#4 |
measure the voltage across C10 when VR22 is bottom, middle & top of it's adjustment range. Disconnect and/or remove D3 & D4. Repeat measurements across C10.
regards Andrew T. |
#5 |
Have you tried measure the bias on R31 and R31.
I don't know this particular amp, but some amps run in Class B on the output devices, while the driver stage handles the low outputs
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#6 |
Value of some device must be uncorrect. Control again all resistors value and connection of biasing transistor...
#7 |
Measuring the bias across C10 is the quick way to really know, rather than haphazardly changing things in the blind. It should be above 2.5V for proper biasing (at least 4 Vbe junctions). If it is too low, increase R21 until you have a good adjustment range. remember that the voltage across R22, R23 total is always max .6V
What are the current values of R21, 22, 23? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#8 |
voltage across R24 1.17v
voltage across C10 2.06v (varies when turning preset R22) (1v - 2.3v) By the way something that I forgot to mention before is that I have included another pair of output transistors to the original circuit so it now has 5 npn and 5 pnp. Maybe that is the little alteration that is making the difference. what do you think ? |
#9 |
Hi leander,
You need to increase the value of R23 to get into the proper adjustment range. Adding the extra outputs will not affect this. -Chris |
#10 | |
Count the B-E junctions across C10: 2 x driver, 2 x output (this is independent of the # of parallel outputs. They are in parallel, so their Vbe is also in parallel, and parallel voltages stay the same. Making a baby allways takes 9 months, irrespective of the number of women assigned to the task So, total 4 junctions x .6V is at a minimum 2.4V. You have not enough biasing voltage. I think you must increase R21 (IIRC the diagram). Jan Didden
| Biasing | fauxpas | Tubes / Valves | 4 | 3rd January 2008 08:06 AM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| Biasing | Wyatt Turk | Tubes / Valves | 10 | 1st October 2004 02:11 PM |
| SOZ Biasing | vdi_nenna | Pass Labs | 21 | 2nd June 2001 03:38 AM |
| Page generated in 0.11214 seconds (79.93% PHP - 20.07% MySQL) with 11 queries |
