http://www.powergood.boom.ru
Schematic - http://www.powergood.boom.ru/ampsch.pdf PCB - http://www.powergood.boom.ru/amppcb.pdf Also on page http://www.powergood.boom.ru/sborka.htm schematic&pcb in Eagle format, scan pcb images. Sorry, but description only on russian. |
#2 |
If possible, as a first step in construction and evaluation, tell me the resistor that must be changed because of Chip supression.
regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#3 |
Carlos,
The TL081 is a very very smal chipamps, you can buy it in saledepartament! The datasheet of this: http://victoria.fis.uc.pt/ppessoais/...Spec/TL081.pdf
Brazilian Tube Amp Builder. |
#4 |
Hi SergVK
Very nice design. Is the prototype ready and working? I'm a bit affraid of the servo mechanism. It can lead to some minor oscillations at very low frequencies if input is DC-coupled because of 180 degrees phase shift. Who knows what's on the output of a preamp. Maybe a cap, maybe no cap. Regards |
#5 |
Hi SergVK
I get a "load error 286" when I open your eagle files. Any suggestions? Thanks
Greg Erskine |
#6 | |
#7 | |
#8 | |
If SergVK can open it he may have an earlier release.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#9 |
Is this too complicated?
There is complexity in the two stage diff arrangement for which there is no evident reason, at least to me. Why? It has a high component count. I do quite like the output stage. Cheers, Hugh |
#10 | ||
I downloaded the zips again and got the same error. Quote:
Greg Erskine |
| Audiophile quality PA at below cost 18" woofer 1500 Watts of AMPS | LuminousMaximus | Vendor's Bazaar | 1 | 31st March 2009 11:17 PM |
| Quality and low cost PCB | Dickson CHAN | Vendor's Bazaar | 0 | 19th February 2009 03:21 AM |
| Professional Quality, Low cost PCB design and Manufacturing. UK | daveB0360 | Vendor's Bazaar | 0 | 3rd October 2008 03:33 PM |
| Best quality and lowest jitter Philips transport assembly? | mburnstein | Digital Source | 8 | 13th January 2003 09:20 PM |
| Page generated in 0.10631 seconds (82.33% PHP - 17.67% MySQL) with 10 queries |
