Hi, i just purchased a pioneer E06 av thx amp (off ebay) and have just turned it on and it wont select any inputs & on-screen setup fails to start......
I opened it up and found one of the ribbon cables is VERY bent & has a few kinks in it and it looks like the problem as its linking the front mounted pcb to the input/output boards. Now, i need to know where to get this ribbon cable , im in the UK aswell so that usually makes things like this a little harder, i really don't want to send it back as i got it for a bargain price but i don't want to fork out for a repair bill either......... btw the cable has around 30 "connectors" on each end & they are all separated down the entire cable. many thanks in advance , James.
#2 |
What kind of cable is it, is it a plastic one with the tracks printed on it? If so, good luck getting one...
if it's normal cable simply check each conductor in the cable with a multimeter on continuity mode and see if any cables are broken. If this is the case you can splice some new ribbon cable into the connectors. Just a question - do you have any experience with electronics ? It sounds like you're not familiar with repair. |
#3 |
hi, yes its a plastic one with the conductors running through it....
anyway i tried the multimeter on it & they are all fine anyway - so looks like it has to go back to pioneer for them to play with and btw , im no tech but get by with the knowlege i have thanks for the advice |
| NAIM 32 internals | pat allen | Solid State | 1 | 19th August 2008 02:56 AM |
| New SI T-Amp, Different internals | schmalex | Class D | 5 | 10th March 2007 05:13 AM |
| tda2007A internals ? | ash_dac | Chip Amps | 3 | 9th July 2006 07:02 AM |
| question on amp internals | duece212 | Car Audio | 6 | 9th March 2006 06:48 AM |
| PCDP with i2s internals? | fcserei | Digital Source | 0 | 5th December 2002 02:58 AM |
| Page generated in 0.07016 seconds (74.03% PHP - 25.97% MySQL) with 10 queries |
