Old 19th October 2005, 12:24 AM   #1
Default Harmon/kardon amplifier
hey, i dont have a clue about diy amplifiers.
but i have a harmon/kardon amp, that i payed 500 bucks for, and it has a 42 amp PS in it.. and it only puts out 80 watts into 8 ohms
just wondering,., any modding potential there, that could significantly increase power or dynamics.
i calculated 42 amps at 120 volts to be about 5000 watts.
what the hell is the power supply 42 amps for if it only puts out 80 watts, that blows my mind.. anyways,.., l'd love to hear some input.
thanks
jaden
My 100$ (final cost) line arrays will blow you away
Old 19th October 2005, 01:06 AM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
my guess is - no way it can supply 42 amps
if its written in the specs of the amp , then its brobably some king of peak current thing or something they made up
or maybe its a class A amp?
model info will help here...
if you are not living on the edge you are taking too much space
Old 19th October 2005, 02:02 AM   #3
its the HK 3380, any takers?
Old 19th October 2005, 02:17 AM   #4
Account Disabled
HK would say anything to sell their products - but can't/don't pay their bills! They have no ethics.
Good LUCK.
Greg
Old 19th October 2005, 02:20 AM   #5
sss's Avatar
yup , no 42 amp supply
if its working then leave it that way ...
Old 19th October 2005, 02:42 AM   #6
bawang is offline bawang  Malaysia
How do you know that the PS is 42A? Is is written somewhere on the amp itself? As far as I know, a real 42A PS (assuming linear) with a decent voltage level for a decent amp will be too heavy, even to lift!
PS: Which part of New Brunswick are you from? I spent 4 yrs in UNB Fredericton (1987 to 1990)....... Gorgeous place....Miss it. Too expensive (airfares) for me to return for a revisit.
Old 19th October 2005, 03:51 AM   #7
I live in Miramichi. i dont think ti was a city then. i have many many friends from fredricton and unb
i own a store here,., car audio/pro sound and home theatre, plasmas and stuff. i love it here
Old 19th October 2005, 07:30 AM   #8
Pity...... Internet technology should have arrived 10 years ago..... Miramichi..... that name invokes memories of my days there. Anyway, welcome to the DIY community.....
Old 19th October 2005, 09:34 AM   #9
Ola is offline Ola
42 amps does not mean a 42-amp PS. It means (well, HK promises) that amp's output stage is able to put out 42 amps in short peaks. How short and is 42 peak-to-peak or absolute height of the peak, is a mystery.
Output volatge is much less, than what comes out of Your wall, so PS amperage is much less also.
But HK amps are really good in handling low complex impedances of speakers, so 42 or less, they are relatively good.
Old 19th October 2005, 01:32 PM   #10
anatech is offline anatech  Canada
anatech's Avatar
Hi jadenlinkletter,
Always remember, to increase power you need to up the voltage internally (new power supply), increase the ability to get rid of heat (new heatsinks and / or fans) and rebuild the amplifier section (new PCB and components). You would probably need a new case as well.
Not worth it, and you are just DIYing a new amp. So for more power, build or buy a new amplifier. I say this because it was almost the most common question I got in service over the years. And you are dealing with the public as well.
The 42 amp rating is for a peak lasting about 1 mS or so. Like discharging a capacitor. I wouldn't run this amp any lower than 4 ohms total load. At high continuous power it may blow anyway due to excessive heat build up.
-Chris
Harmon Kardon argonrepublic Solid State 2 23rd June 2009 07:30 AM
Harmon Kardon PM 640 amplifier bentley ess Solid State 1 9th March 2007 08:06 AM
Harmon Kardon T40 jaudio Analogue Source 0 7th May 2005 12:04 PM
Harmon Kardon Ballad Stereo Amplifier mjhutten Tubes / Valves 1 10th January 2004 12:02 AM
Harmon Kardon Citation 16 amplifier schematic needed csd Solid State 2 7th November 2002 11:11 AM
Page generated in 0.09129 seconds (84.78% PHP - 15.22% MySQL) with 10 queries
