Old 17th October 2005, 06:59 PM   #1
Progg70 is offline Progg70  Sweden
Cool How calculate the output power
If I have +/- 12 V power supply and 4 ohm speaker, what is the output power then?
What is the formula? See the circuit in the picture.
regard
Progg70
Old 17th October 2005, 07:10 PM   #2
edl is offline edl  Hungary
edl's Avatar
Dear Progg,
+/-12V supply gives about 10W RMS power on 4ohm.
You can calculate the output power with Ohm's law, considering the rail losses.
Anyway the attached design will not working...
Old 17th October 2005, 07:59 PM   #3
Cool What!? Way will it not working?
Old 8th April 2007, 12:23 AM   #4
Send a message via MSN to Denis.BR
I'm not sure if this is right....
I read somewhere that yo can calculate the output power using a shower resistance plugged into the output and generating a sine wave. Then you measure the output voltage and apply in the formula:
W=V*V/Z
where W is the power in Watts, V is the output voltage and Z the resistance, but I saw another formula that seems more correct but I can't remember.
Please, correct me.
Old 8th April 2007, 10:09 AM   #5
the amplifier has two limits for output power.
First, the +-12V limits the peak voltage into the load to about 3 or 4 volts below the supply rail (less the ripple).
The power limit can be calculated from Ppeak=V^2/Rload
Power=V^2/(2*Rload).
The output stage is a single ended ClassA. The peak output current is limited to the set value of the output bias.
The power limit for current is Ppeak=I^2*Rload
Power=I^2*Rload/2
From this last formula you will see that using a lower load value LOWERS the output power limit. The first formula shows that a lower value of load raises the output power limit.
You need to calculate both limits.
As one increases the bias current the heatsink and the output devices run hotter and soon will lower the SOAR to such an extent that the devices will blow up. This is particularly true with low impedance/low sensitivity loads.
regards Andrew T.
Old 8th April 2007, 02:01 PM   #6
Amp_Nut is offline Amp_Nut  India
If I have +/- 12 V power supply and 4 ohm speaker, what is the output power then? What is the formula?
With +/- 12 Volt Poweer supply, you have a total supply voltage of 2 x 12 = 24 Volts.
Assume that the Voltage loss on EACH output transistor is 1 Volt.
Then the output will swing 24 V - 2 V = 22 Volts.
Hence your 4 Ohm sees a max voltage accross it of 22 Volts Peak To Pek.
Divide Peak To Peak volatge by 2 x root 2 to get the RMS Voltage.
Hence 22 Divide by 2.828 = 7.779 Volts RMS ( i.e. 7.8 Volts RMS)
Power = VRMS x VRMS Divide By R
R = Load = 4 Ohms
Power Output = 7.8 x 7.8 / 4 = 15 Watts.
This assumes that the transistors, and the power supply can deliver... and that the Voltage swing & current from the driver transistors is enough to drive output transistors.
Old 8th April 2007, 02:41 PM   #7
bear's Avatar
You can ignore one rail.
multiply the measured zero to peak output voltage by 0.707. (one half of peak-to-peak, and easy to see by inspection on a scope) that is the square root of 2.
use that voltage in the Ohms law equation(s).
as someone noted: P = E^2 / R
Best method is to use a real amp on a real load resistor, with a scope that is calibrated or else an RMS meter to get the voltage.
Alternately you can just measure the voltage across the load, and determine the current. That will also tell you the power using Ohm's law.
You may use one rail voltage to approximate the expected power output. In that case the rail voltage is considered to be "peak" voltage, so multiply by 0.707 then plunk that into Ohm's law for power. The real power output will always be lower.
_-_-bear
PS. The attached circuit is trying to be a SE class A amplifier??
Why?
Seems like a long way to go for not very much... why not P-P?
And, if ur going to go SE class A, there are better, and easier to build circuits out there... the output in a real world amp needs to be servo controlled or cap coupled to prevent major DC offsets - I presume the last resistor that is being shown measured across is the RL (load - speaker)??
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 8th April 2007, 02:56 PM   #8
Hi Ampnut,
you know that this condition cannot be met with 1off 2n3055 output transistor running single ended.
so what is the point in telling him this result?
It would require the bias to be set to at least 2.75A just to deliver that power into 4r0. Since most speakers will draw current that exceeds the 4r0 value, it means that bias will probably need to be set to somewhere between 3A and 4A to get that power prediction into a 4ohm speaker.
The dissipation in the current source and in the output device will now be around 40W each. That is one mighty strong transistor for a 90W device and one heck of a heatsink to stop it blowing up before he even tries to put a signal into the amp.
regards Andrew T.
Old 9th April 2007, 02:54 AM   #9
Send a message via AIM to JasonLee Send a message via MSN to JasonLee Send a message via Yahoo to JasonLee
I had learn this from some books
Vcc2
Po = - --------- X 0.8
8 RL
Po is Output power
For +/- 12Volts take is as 24V
RL is speaker impedence. ( 4 ohm )
Old 9th April 2007, 07:21 AM   #10
no.
Measure the Vpp or the Vpk of the output sinewave and use this to calculate the Vac applied to the load. Vac (=Vrms) = Vpk/sqrt(2) =Vpp/{2*Sqrt(2)}
The predicted power from the formula P=Vac^2 / Rload is exact. Not lower.
regards Andrew T.
Lateral MOSFET, How do I calculate power output synonymous Solid State 4 18th December 2007 06:54 AM
Calculate PSU output impedance? jayme Tubes / Valves 1 19th May 2007 07:27 PM
How calculate the output power Progg70 Solid State 2 19th October 2005 03:57 PM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
How do we calculate an amp's input and output impadance? Bricolo Pass Labs 1 13th January 2003 09:26 PM
Page generated in 0.12045 seconds (81.53% PHP - 18.47% MySQL) with 11 queries
