Hi there
Will try to build the famous JLH class A amp (new 1996 version) - but theres a few things in the diagram I'm in doubt about: The only high power resistor is the R10 0R33 ? Is the middle leg of the 7815(connected to R4) left floating - it is not connected to 0volt or ground ?? Why is the output of the 7815 going to the other channel - cant I just build two seperate channels like the schematic ? Is there any components where special quality is worthwhile - caps/resistors ? Thanks ! Buhl
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass |
#2 |
forgot the schematic.....ups !
Cheers ! Hans
#3 |
#4 | ||||
Hi Buhl
Resistors R2, R3 (signal input) and R6, R8 (feedback network). The signal also appears across R5 & R9 Capacitors C1 - I suggest a good quality polypropylene (preferrably film and foil rather than metallised film) or, if you can afford it, a paper-in-oil. C2 - polystyrene. C4 - a good quality electrolytic (preferrably bipolar) Please note that there is an error on the schematic that you posted. The negative end of C4 should go to 0v (ground) and not to the -ve rail. Geoff |
#5 |
Thank you Geoff and calebay - seeing the "updated" schematic I think I will go for that one - the idea of a CCS instead of a chip voltage regulator seems more "right" for me....
The link for the updated version gave me a lot of things to work with - thank you ! One thing - how nessecary is it to use active regulation of the PSU - I was thinking of skipping it i favour of a C-R-C-C(44000uF-0R5-44000uF-44000uF) filter.......? Cheers ! Hans
#6 | |
| 10,000 watt class D amp | BillyDoc | Class D | 19 | 8th May 2009 06:58 PM |
| 2500 watt class AB | hienrich | Solid State | 21 | 4th October 2007 10:03 AM |
| pass 20 watt class a | amp-guy | Pass Labs | 1 | 17th October 2004 09:38 AM |
| JLH 10 Watt class A amplifier #2 | DomKo | Solid State | 8 | 30th October 2003 11:32 AM |
| Page generated in 0.08537 seconds (78.82% PHP - 21.18% MySQL) with 11 queries |
