A simple question from a simple man. - diyAudio
Old 17th October 2005, 09:50 AM   #1
Default A simple question from a simple man.
I am back with a new idea. My Rotel RC-971 preamp has a bit fo a strange design. It has an option to record one source (sends one source unmodified to the tape outs) at the same time as listening to another (sending another to the preouts).
The headphone preamp is obviously connected to the listening option.
What i want is to be able to listen to one thing on my headphones while playing something else on my speakers.
What I was going to do is find the connecting wires that goto the headphone amp section and move them onto the tape outs.
In theory that means the headphones will play whatever I am recording and the rest of the amp will act as normal.
I use my headphones to listen to my PC (which has its own volume so it matters not that I am bypassing the vol pot) and I want to listen to CD's at the same time.
So what am I overlooking?
Peter
x
Old 17th October 2005, 10:53 AM   #2
Did it Himself
richie00boy's Avatar
You can't do it. Headphones is derived simply by a resistor on the output of the amp. So need to build a dedicated headphones amp and connect that to the record pre out.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th October 2005, 11:07 AM   #3
I just opened up the box. I can confirm, its downright impossible.
I thought theese things would have a headphone amp PCB with some nice trailing wires!
All one one (almost empty) PCB that is upside down. The board has been glued in place so you can get to the useful bits anyway.
One side note, if it is really as simple as just a resistor on the outputs why is there a thing about the quality of headphone amps built into pre's. The headphone amp in this is supposed to be very good. So what does that relate too?
In theory, could i not just solder some resistors on the tape out and connect the headphone socket to that? I wont do it, its just not worth the hastle, but I'm curious as to why or why not it would work.
I have never had a project crash and burn so fast, 15mins from idea to death!
It took me six months from the idea to biamp my speakers to do it (even though I have a spare similar unused amp on top of my wardrobe)
Well thanks for the help.
I now have to reattach my pre to me hifi rack. problem being is I glue it on! this is going to be tough.
Peter
Old 17th October 2005, 12:44 PM   #4
Did it Himself
Sorry I missed the pre bit and just saw amp. It will have a dedicated amp bit for headphones. Doing what you want will involve cutting tracks and splicing wires in. In this age of cheap and easy to make goods everything is on one PCB usually with as little hard wiring as possible.
Old 17th October 2005, 02:54 PM   #5
Why do you glue your preamp?
Old 17th October 2005, 03:00 PM   #6
Default prepare for incoming flac
Well,
<-- nervously shuffles his feet.
I have limited shelves on my hifi rack.
So for space saving I utilise both the top and bottom of one of the shelves =-)
It works so you cant knock it!
just taking it off to service is a bugger, not to mention the amout of pritstick needed
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Simple Question stoN_Cold Solid State 2 3rd October 2005 10:56 PM
Simple question... Quattor Solid State 7 23rd June 2004 05:41 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
simple question W.O.L.F. Pass Labs 6 1st August 2002 03:12 PM
Copyright 1999-2017 diyAudio
