Old 18th October 2005, 12:42 AM   #11
Enzo is offline Enzo  United States
Please don't call them "stereo" jacks unless they are used to carry two channels of signal information. You have confused the man. They are TRS jacks - tip, ring, sleeve - which are used as a balanced input. People often call them stereo jacks, but it is a poor use of the term. Each jack handles ONE channel of signal, but the tip and ring contacts on the thing allow for a balanced connection.
A stereo output such as for headphones can use a TRS jack, but all TRS jack applications are not stereo. This is a perfect example of why not to label them that way.
Old 18th October 2005, 01:06 AM   #12
Account Disabled
Hi Enzo
Yes I appreciate what you're saying. I was simply trying to communicate in jargon that jonz could possibly relate to.
TRS, TRS,TRS... OK jonz?
greg
Old 18th October 2005, 07:08 PM   #13
Is it possible to convert a balanced TRS connection to an unbalanced phone jack connection?
Old 18th October 2005, 10:41 PM   #14
jonz is offline jonz  Canada
Thanks Ampguru..I figgured it out thanks to you guys....I can't believe something so simple could have eluded me...
I split the signal from my H.T. receiver LFE pre-out with an rca 'Y" going to 1/4 mono to rca adapters to the inputs of the behringer and from there I use a pair of 1/4 mono's to my amplifier which already accepts xlr's/neutriks/ 1/4's..now the hard part of adjusting the filters on the eq......
Old 19th October 2005, 07:04 AM   #15
dnsey is offline dnsey  United Kingdom
Just use a standard 'mono' plug. The ring and sleeve connections will then be shorted, which is what you require.
Note that some cheap and oddball plugs aren't made to standard dimensions, so use something well-known and decent quality.
Old 19th October 2005, 12:32 PM   #16
dnsey,
Thanks for the clear assurance that conversion is simple.
Dick
Old 22nd October 2005, 02:29 AM   #17
I'm a little bit surprised that your using it with a sub. Most of the feedback is higher frequencies. We had one at a church I used to work in and it was quite good up to a point. As I understand it it will lock on to the particular frequency that is screeching away and then insert a notch filter. It can do this for a large number of frequencies. We only struck one problem with it. At regular intervals it would completely fail and the only explanation anyone came up with was that the local power company wass ending a signal down the mains AC to turn on domestic hot water systems and this was resetting the supressor. They were going to insert a filter in the mains to see if that cured it. I didn't hear whether it worked or not.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 22nd October 2005, 03:43 AM   #18
Actually the parametric eq part of it is used to smooth out a sub 's response.. if you want to read more you can go here
Old 22nd October 2005, 04:03 AM   #19
Thanks jonz. That makes sense. I knew it was a flexible device. We only bought ours for the feedback problems. One of our daughters just moved to Canada recently and had a w/end in Montreal.........it sounded like a good plce. Cheers. Jonathan
Wtb Feedback destroyer or similar product sanjeev Swap Meet 0 27th April 2009 01:41 AM
BFD Feedback Destroyer (EU/UK) jimbo1968 Swap Meet 0 23rd November 2006 06:38 PM
help with behringer feedback destroyer and amplifier noise noodle_snacks Digital Line Level 1 11th July 2006 12:40 PM
FS: Behringer Feedback Destoyer DSP 1100 ebag4 Swap Meet 0 14th June 2006 08:44 PM
Feedback Destroyer Pro Dsp1124p soloxp Subwoofers 4 18th May 2006 12:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
