Hi, Just asking if someone else ever had this kind of problem. I have a faulty channel that goes into protection mode. Just take a measurment between center tap and the case and found that there's +70 volts. When measuring between both center tap I have the same reading of +70 volts.When measuring between center tap and transistor collector ,the reading is ok i.e. +70 and minus 70 volts.
Reading is 7.8 and 7.1 at base and collector respectively, that's why the protection goes on, but could not find any clue about the voltage reading of 70 volts between center tap and case. Have any idea, please let me know, Thanks |
#2 |
Hi ostie01,
At this point I have to say, buy the service manual. It will have the foil layout which you are going to need. I don't think they are that expensive to buy at Denon (800) 263-1692, Chris in parts will give you a price. -Chris |
| Problem with Denon DRA-455 | smithy666 | Solid State | 0 | 29th June 2008 08:20 AM |
| Another A40 Ground Problem | gpsmithii | Pass Labs | 9 | 17th August 2006 01:24 PM |
| Bias adjustment on denon POA2400 | ostie01 | Solid State | 1 | 14th October 2005 11:20 PM |
| no ground problem | trancy | Tubes / Valves | 2 | 27th March 2004 01:53 AM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Page generated in 0.06341 seconds (69.68% PHP - 30.32% MySQL) with 10 queries |
