Old 16th October 2005, 07:45 AM   #1
Raj1 is offline Raj1  United Kingdom
Default concept amp by Steve Eddy help required
I would like to give this amp a try, just out of interest. I know this sort of stuff doesn't appeal to everyone, but I would still like to give it a try, without rousing negative posts......
http://www.diyaudio.com/forums/attac...amp=1059159077
Can anyone suggest the mosfets I should use and the rail volatages required?
1 watt should be fine as I have very sensitive speakers and don't listen too loud.
At the moment I have regulated supplies with 50v torroids, but perhaps the rails will be to high at 70 v? However it would be nice if I could use the parts I already have without purchasing more.
If anyone can suggest mosfets that can handle the 70v voltage for around a 1W ouptut it would be great.
many thanks
Raja
PS I have plenty of heatsinks to use.....
Old 16th October 2005, 08:08 AM   #2
PMA is offline PMA  Europe
PMA's Avatar
Pitty that Steve has been sinbinned. The more voltage, the more linearity, as there is no other means to improve it
Old 16th October 2005, 08:31 AM   #3
Hi PMA,
can you please suggest which mosfet to use etc?
Raja
Old 16th October 2005, 08:38 AM   #4
PMA's Avatar
Let's wait for Steve to advise. In case of power stage, I would use IRFP240, 244 or 350.
Old 16th October 2005, 11:56 AM   #5
SY's Avatar
Steve will be out in two days.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 16th October 2005, 04:18 PM   #6
I don't know the whole story but that deleted thread was a bit extreme. What else do you call an enclosed transformer that has it's coat taken off and still inject a little humour? I was waiting for some tech info coming back.
The transformer shown in this thread will reflect a multplied impedance into the fets (varies as the square of the turns ratio). This circuit will probably work better if the input impedance is kept low and the transformer does the opposite. What's the solution?
regards Andrew T.
Old 17th October 2005, 07:12 AM   #7
tlf9999 is offline tlf9999  United States
Account Disabled
I have done that with a radio shack signal transformer, reversely connected, to drive an irf540.
It sounded fine. the only problem I see is that you will have to use a very powerful driver to get good quality sound. In my case, my driver was biased over 80ma for good sound.
the radio shack signal transformer (<$5 each) has a 1:10x ratio (give or take a few).
Eddy Currents jsa_ind Solid State 3 14th May 2006 09:05 AM
The 'Interface' - Steve Eddy? shuang Everything Else 107 30th December 2003 02:35 PM
Steve & Frank & Steve start a Love-In Steve Eddy Everything Else 25 6th November 2002 06:02 PM
Page generated in 0.09108 seconds (76.21% PHP - 23.79% MySQL) with 10 queries
