Old 9th January 2012, 09:12 PM   #31
tiefbassuebertr's Avatar
Originally Posted by stef1777 View Post
Hi Martin!
Thanks for this schematic but I did a mistake. I requested the s1 model but in fact, I have 2 models: s2 and s3 nor s1.
If you have these ones too, thanks in advance. Specially, the s1 model witch is the one in trouble. I have big "ploc" at startup and when powered off.
Stef...
A very fine sounded amp, if one have a correct dimensioned external (outdoor) power supply include choke. The genuine power supply, especially the caps are too small for proper sound.
A Question: What is the correct term in the colloquial english language for the heatsink assembly aluminium block, that press the power transistors on the surface from the heatsink - also to find inside of Mission Cyrus about follow link?
http://ftbw.de/files/resources/Cyrus_II_inside.png
Old 23rd May 2012, 07:06 PM   #32
hello all, why would RP1 & RP2 (marked) cook?
WANTED: Creek Destiny POWER amplifier
Old 24th May 2012, 06:16 AM   #33
Mooly's Avatar
Would need to see the circuit to tell you that...
I see the transformer says "220Vac". Mains in the UK can reach as high as around 256 on a good day I don't know why it would say that but for a UK product that is wrong and taken at face value means the DC rails in the amp could be somewhat higher than expected with possible problems due to over running parts/caps and consequent increased power dissipation.
A simulation free zone. Design it, build it, test it.
Old 4th June 2012, 10:46 AM   #34
lohk is offline lohk  Europe
lohk's Avatar
RP1 and RP2 probably are the resistors for the power regulators for the input stages. If you have a too high voltages (because of highish mains supply) they have to work hard and get very hot.
/lohk/
Looking for Creek CAS 4040 Schematic truenorth Solid State 2 17th February 2009 11:51 PM
Creek 4040 s2 transistors or schematic jjanderson Solid State 10 2nd July 2008 11:36 AM
Creek CAS 4040 problems and speaker coupling electrolytic query bikelectro Solid State 0 7th May 2008 02:11 PM
creek MM phono bd. schematic audioray Analogue Source 0 10th April 2005 02:01 PM
Copyright ©1999-2013 diyAudio
