Old 15th October 2005, 12:04 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default How to subtract 2 signals without an opamp? (discrete or not)
I'm looking for a way to subtract 2 signals, but using an opamp subtracter topology.
In fact, without feedback at all.
Does anyone have a clue?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 15th October 2005, 12:11 PM   #2
analog_sa's Avatar
What is your application? Is a transformer an option?
Old 15th October 2005, 12:35 PM   #3
Bricolo's Avatar
I's for a subtractive crossiver project.
I'd prefer not to use transformers
Old 15th October 2005, 12:41 PM   #4
johnnyx is offline johnnyx  United Kingdom
Would a series crossover be ok?
Old 15th October 2005, 12:44 PM   #5
MikeB is offline MikeB  Germany
MikeB's Avatar
How big are the signals that need to be subtracted ? Linelevel or powersignals ?
Obviously, if you don't want to use any feedback, opamps are not welcome ?
A simple diffamp typically effectively subtracts two signals, that's why it is called diff-amp...
Or you use an "simple" inverter, and use additive resistors ?
Mike
Old 15th October 2005, 01:11 PM   #6
Bricolo's Avatar
It's for line level signals (IOW: active crossover, so no series one)
No feedback, you' right Mike.
a discrete open loop inverter (do you mean a common emitter with Rc=Re?) and an adder? Yes, that looks like a solution. I'll check that, thanks.
I remember having seen a "1 transistor" subtracter somewhere on this forum, but don't remember where exactly . IIRC it has an input on the base, and the other at the collector (or emitter, don't remember exactly)
Old 15th October 2005, 01:17 PM   #7
You can basically use a single BJT and use the base and emitter as inputs. However, using a diff pair will give a much much more linear solution. If you look at the transfer curve of a diff pair, you see that it is very linear within a certain voltage range and quickly becomes very non linear outside it (well, there is no sharp transition, of course). Emitter degeneration extends the linear region. You can either do the math, or just play with Spice and see what the transfer function looks like for various values of emitter degeneration.
Old 15th October 2005, 01:28 PM   #8
Bricolo's Avatar
in fact, charles alreadyd did everything I wanted to do
Active Subtractive XOs
990 discrete opamp udip Solid State 18 12th February 2009 11:00 PM
Discrete OPAMP audio-gd Vendor's Bazaar 26 11th October 2008 10:58 AM
My discrete opamp udip Solid State 51 8th August 2006 07:33 AM
Page generated in 0.08065 seconds (77.42% PHP - 22.58% MySQL) with 10 queries
