Old 14th October 2005, 10:07 PM   #1
Antonix is offline Antonix  Italy
Default substitutes for 2SC3519
Hello community.
I have thinking to change the old 2SC3519/2SA1386 of my Carver because I owe to drive a difficult speaker at 4ohm and i want to have more current.
I want to leave the 2sc4381/2sa1667 drivers for the moment.
What do you think about ?
Old 14th October 2005, 10:14 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Antonix,
1. Carver amps will drive a 4 R load normally.
2. What is the model number of your amp?
-Chris
Old 14th October 2005, 10:30 PM   #3
The model is TFM 15 and have 4 bjt / channel.
The devices were several year old and I want to change with more performant devices.
My speaker are 4 way self-made Hi-End and I have necessity to drive with little more current.
Old 14th October 2005, 10:44 PM   #4
anatech's Avatar
Your original parts are rated for 15A, 130W with an fT of 50MHz.
You can try the latest ON Semi parts, small gain. And remember, a 4 R load is a 4R load. I guess you mean to "crank it". You still have a heatsink sized for the original temperature rise, and the thermal in the power transfomer may go first anyhow. This amp is no toy but it's not a Krell either.
-Chris
Old 14th October 2005, 10:54 PM   #5
I look for MJL21...
Old 14th October 2005, 10:57 PM   #6
anatech's Avatar
Those are what I was thinking of. You will need to drill new holes higher up as those are a bit longer. Tap them 3 X 4 mm to do a nice job.
-Chris
2sk3662 substitutes? shagone Car Audio 8 29th November 2011 04:33 AM
Substitutes cobology Parts 0 21st February 2009 08:59 PM
Op Amp substitutes mosfetti Solid State 8 7th December 2007 01:13 AM
7868 substitutes AmpKiller66 Tubes / Valves 7 21st November 2007 03:19 PM
Transistor substitutes Vivek Solid State 0 8th October 2001 08:24 AM
Page generated in 0.08073 seconds (71.47% PHP - 28.53% MySQL) with 10 queries
