Old 11th October 2005, 09:20 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Any suggestion for a decent input JFET pair?
I am searching for a decent JFET input pair, it would operate with drain current between 1 - 2 mA. I have not worked with JFETs that much, so any suggestion would be greatly appreciated. It should be an available type.
Old 11th October 2005, 10:05 AM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi Pavel,
I could recommend the 2sk170, at www.schuro.de you get them for a
reasonable price, original Toshiba-devices. (That's where i bought them)
The sk170 has max Vds of 40v, and i already used it in several designs,
without any problems. It has at least the transconductance of a "poor" bjt...
The 2sk389 is also interesting, it's a double device, i have some but not
used yet, so i don't know how good the matching is.
Mike
Old 11th October 2005, 10:07 AM   #3
bocka is offline bocka  Germany
Similar to OPs! Offset voltage is some mV
Old 11th October 2005, 10:15 AM   #4
PMA's Avatar
Default Forgot to say that I need N-JFET + P-JFET
Hi Michael nad bocka,
thank you for your recommendations. I forgot to say that I need a couple of different conductivity, i.e. N-JFET + P-JFET.
Pavel
Old 11th October 2005, 10:22 AM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Pavel,
the partner of the 2SK170 is the 2SJ74, 2.5 times more pricy though.
Looks like Sponge Bob has killed another thread.
Old 11th October 2005, 10:23 AM   #6
MikeB's Avatar
Okay, in this case, 2sk170 + 2sj74 !
But the 2sj74 has max Vds of only 25v...
I've build complementary circuits using these 2, worked fine !
Mike
Old 11th October 2005, 10:24 AM   #7
PMA's Avatar
Thank you jacco and Mike, I will download datasheets and review these components.
Old 11th October 2005, 10:40 AM   #8
to check for pairs :
http://www.geocities.co.jp/Technopol...in/tr_data.txt
Dalbani in the UK still has some of the complementary pairs.
Old 11th October 2005, 11:22 AM   #9
aparatusonitus's Avatar
If you are going to use 2SK389 in complementary topology, then you also need 2SJ109.
OT - Could you show as a balance version schematic of your error correction amp, as you promise long time ago (if i'm not mistaking), thank you.
Best, a
Old 11th October 2005, 12:05 PM   #10
PMA's Avatar
Originally posted by aparatusonitus
I
Best, a
I am afraid there is not much to say about it, 2 identical modules connected as follows:
Wanted Urgent (UK)- A pair of decent Male RCA plugs... (and a few other pieces) Peteruk Swap Meet 4 26th July 2007 05:38 PM
WTB\WTT a pair of decent in-ear headphones demogorgon Swap Meet 0 4th May 2006 05:25 AM
JFET complementary pair Leolabs Solid State 18 7th January 2006 06:27 AM
JFET pair anli Solid State 2 6th December 2004 01:19 AM
Page generated in 0.09697 seconds (76.23% PHP - 23.77% MySQL) with 11 queries
