Old 10th October 2005, 04:55 AM   #1
Default power supply for car amp in house?
What would be a good rating to run a pretty large, but class D if that helps, car amplifier in my house for a pair of subs? It is a Kenwood KAC-9102D mono amp with a rated 500watts RMS into 4 Ohms. Not sure that I believe that rating, but for the sake of being overcautious, let's say it's correct.
Am I looking at 10A 13.8 volts supplys or more like 20A?
Thanks guys.
Greg
PS. would using a big CAP like the car audio guys make any difference in the needed size?
Old 10th October 2005, 06:15 AM   #2
Chartal is offline Chartal  Canada
If you do the math, 13.8V x 10A = 138W, really far from 500W!
500W/12V=42A RMS.
Good luck to find that big supply.
Or you can uses a 12V car battery (sealed) and charge it
between listening.
Old 10th October 2005, 07:09 AM   #3
Account Disabled
Way to go, Chartal - The car battery is the versatile solution. Not only is it smooth, and possible to charge from renewable sources (eg. solar,wind gen, or an off peak plugpack wired into your hot water) but you can listen during blackouts, and have a backup car battery if your's fails.
In reality, I doubt it would holdup too well with 13.8V with that draw and nothing coming in, but there's relief breaks in the music and crest factor even in bass, so a 1A trickle feed wallwart may be innocuous.
You could set up an exercise bike with an alternator and pedal for more bass!
greg
Old 10th October 2005, 07:55 AM   #4
Account Disabled
Just think - if there was a technology that existed wherein you could harness all the argumentative energy of siblings growing up and harness it to play soothing music, I WANT IT!!!
Greg
How to power Car amp in my house icecoolwas Class D 12 24th December 2008 09:20 PM
DC power house needs PS for D1 and F1 khundude Pass Labs 2 19th November 2008 06:13 AM
Power company, powerline transformer distance to house hags Everything Else 1 8th October 2007 10:00 PM
Power amp loading on house wire chris ma Everything Else 10 22nd June 2004 11:51 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.07160 seconds (69.56% PHP - 30.44% MySQL) with 10 queries
