Hello,
I am looking for schematics or at least bias adjust description of that amp. Many thanks in advance!
Power To The People |
#2 |
A nice way to set the bias is applying a low input signal, looking at the distortion with a scope and adjust till the sine wave looks neat. Usually I turn the pot even a 'little' higher.
/Hugo |
#3 |
Dear Audiotech!
STA-700 schema attached, maybe it helps... Regards, |
#4 |
Hello,
thanks both for replies. This stage line has made driver stage with BF757 and BF 760. End transistors are mosfets 2SK1058 and 2SJ162 (two in rail). After repair of one channel (one broken 2SK1058) and switching on drivers of both channels get hot and I think too hot. I measure the heatsinks temperatures (on each driver heatsink separate) and are 2-3 minutes after switching on about 55-60 degrees Celsius. It seems too hot and that the bias is set to high. It will be nice If someone has schematics with these transisitors used or at least datasheets of the BF drivers where I can see If this is normal. There is no distortion on sound and the sound is clear to his maximum output. Regards, Audio Tech
#5 |
Hello,
I found out that the drivers working temperature is around 82 degrees Celsius meausered directly on his heatsink. After that I set the bias properly. Regards, Audio Tech
| Which DHT for Line stage? | andyjevans | Tubes / Valves | 15 | 26th March 2009 01:10 PM |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| #26 line stage help | Original Burnedfingers | Tubes / Valves | 4 | 9th July 2004 10:56 AM |
| Line stage | woody | Tubes / Valves | 5 | 10th August 2003 08:55 PM |
| Page generated in 0.07265 seconds (73.49% PHP - 26.51% MySQL) with 11 queries |
