Old 4th October 2005, 04:38 AM   #1
murat is offline murat  United States
murat's Avatar
Default Where do you find Heatsinks
In the main stores like digikey, mouser, newark.. I can't see much choises for power transisor heatsinks. I am especially looking for TO-3. What is your favorite retail supplier for heatsinks? Thanks
Old 4th October 2005, 08:18 PM   #2
dutch diy's Avatar
Send a message via ICQ to dutch diy
Default TO-3 heatsinks..
Hi Murat,
I had a difficulty finding large heatsinks for TO-3 also.
So I made them myself:
A large L profile (40 x 40 x 4 mm ) 30 cms long. One side drilled with holes to hold two TO-3 and one TO-216 pack.
This was bolted to a 200 x 20 x 300 mm 'normal' heatsink.
I repeated this 4 times and ended up with :
J-amp powers Avantgarde-Acoustic Trio
Old 4th October 2005, 08:20 PM   #3
dutch diy's Avatar
Default btw
the heatsinks came from www.schuro.de and the L profile (and all the other ALU stuff) from my local hardware supplier.
Old 4th October 2005, 08:31 PM   #4
wchick is offline wchick  United States
You should be able to find some on Ebay. Search "Heat sink" or "heatsink" under the category of Industrial Electrical, test. I used to get my sink from there. Hope this help.
Old 4th October 2005, 10:27 PM   #5
murat's Avatar
Thanks a lot guys!!
Dutch man, this is really smart. Did you use some thermal compund between the L-bar and heatsinks? How many bolts did you use per one side? I presume fastening the bolts real tidht would give a good thermal conductance. Very much liked the idea!
Old 4th October 2005, 11:34 PM   #6
mzzj is offline mzzj  Finland
I take a look around local junkjards sometimes, last time i bought 40kg of aluminium, 4pcs of huge heatsinks. They had 600kg batch of those, some sort of faulty batch. backplane was not smooth and they were slighly warped from edges but after milling they are going to be just perfect Has to start looking for Pass Labs desings to get use for them
Old 4th October 2005, 11:55 PM   #7
Enzo is offline Enzo  United States
And cruise the surplus electronics outlets, they often have heat sinks.
Old 4th October 2005, 11:58 PM   #8
wes-ninja250's Avatar
I buy mine from bgmicro.com -- oddball selection (email to make sure what you want is actually in stock), but dirt cheap and easily accessible.
I recently bought a bonded-fin copper duron(?) heatsink and cut/tapped it to fit my purposes.
Wes
Do daemons dream of electric sleep()?
Old 5th October 2005, 07:57 AM   #9
AKSA is offline AKSA  Australia
Try this one from downunder:
www.conradheatsinks.com
Shipping is expensive, but the product is so good and inexpensive compared to the usual fare that it's worth it.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 5th October 2005, 08:11 AM   #10
Account Disabled
Hi Hugh,
It's good to point out that the claimed thermal ratings are for an 80deg C temp rise and that those for a lesser rise are roughly 15-20% higher (poorer), also they are done with the HS totally exposed to the air including the normally enclosed flat or flanged surface. A good idea is to take the flanged version as the more realistic indicator of HS efficiency when encased.
No surprises.
greg
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
WTB: Heatsinks kestrel200 Swap Meet 7 5th February 2005 10:02 PM
SK-109 Heatsinks Leeuwarden Swap Meet 8 11th December 2004 09:19 AM
I find a heatsinks gogo Pass Labs 1 25th February 2003 02:02 PM
where to find big heatsinks? wake rider Solid State 3 14th January 2002 03:38 PM
Page generated in 0.09981 seconds (78.08% PHP - 21.92% MySQL) with 10 queries
