Old 1st October 2005, 09:37 PM   #1
opp is offline opp  Denmark
opp's Avatar
Default !!>optimize active xover amplifier choice
Hi – tried to make this tread Link come a live in the loudspeaker forum, little success though. I am new to this forum, hope you will bear with me, if this “reposting” is improper.
As DIY’er I am always trying to optimize my investment in Hi-fi. (guess that’s a common goal /necessity for all on this forum). Amplifier design is a question about compromises, so my reasoning is: if you have an active xover, it must be possible to optimize the amplifier choice for each frequency range.
I have a renovated Quad 405, UCD 180 and a 10 year old NAD 30 watt, for a 3-way active system. It is the latter that has to be replaced.
My hypothesis is that the treble need special attention, on the other hand the power demand is low. It must be possible to find a most favorable amplifier for this purpose – that is really the topic.
I imagine a small high quality class-a (10-20 watt), is that a good choice? If yes – can someone recommend a design with a commercial available PCB?
Or should I go for another design?
time flies like an arrow ... and fruit flies like a banana
Old 1st October 2005, 10:57 PM   #2
darkfenriz's Avatar
Default Re: !!>optimize active xover amplifier choice
Probably good choice, but it is frequently overlooked that despite low RMS or average power, trebles sometimes demand high pulse current.
So it is good to have some power/output swing margin for tweeter amp.
Old 1st October 2005, 11:02 PM   #3
Account Disabled
Hi opp,
You are correct that amplifiers can be chosen on their merits for the respective frequency band - big heavy duty AB for bass, medium finessed AB for mids, and smaller (but enough for transients) low distortion for top.
I would apportion say 200W 4ohm BASS, 150W 8ohm MID, and 50W treble.
Your BASS amp should be clean clipping and have competent PS and heatsinking for continuous duty.
The MID amp can be more finessed for lower duty but clean with good PSRR and low THD.
The treble amp could be a good quality AB amp with no significant complex non-linearities and low THD, or a Class A.
Hope that helps,
greg
Old 1st October 2005, 11:09 PM   #4
bogicp is offline bogicp  Yugoslavia
bogicp's Avatar
hi opp,
I'm also new "in town".
One thing that is in my mind when I read your message, is that you must choose tweeter driver first. Not all tweeters can be driven with 10-20 watts with succesful sound pressure level in respect to other drivers... if you cannot define tweeter driver you must expect more than 20W power for it.
Best regards
-boggy
Old 2nd October 2005, 08:05 PM   #5
opp's Avatar
Yes - the tweeter sensitivity is an important detail, as bogicp points out. The tweeters will be Vifa XT25 or maybe the new Seas Crescendo, both with a sensitivity around 91-92 dB, the woofers is approx. 88 dB. This fact (together with the lower power demand I the treble) points towards a small amp. But the argument that treble demands high peak current/voltages points in the opposite direction.
Maybe a compromise is a design with nearly the same voltages/current level as the woofer amps, but equipped with transformer and cooling according to the actual needed average watt-effect (the expensive parts). The demand for peak current could be handled by large reservoir caps – would this work? Well - probably not with a class-a design - or?
Old 2nd October 2005, 08:26 PM   #6
bogicp's Avatar
hi opp,
I probably speculate, but you cannot easily determine that you need only current... Class A has problem with overheat if you use larger supply voltage... but if you only need current I think that you can obtain good transient response with good capacitors (you must have extra supply caps, polypropylene 1u near to output transistors). Also, you must do PCB design very carefuly. Try to keep this tweet amp small as possible, with short and thick lines, this is only way to obtain good transient response and not degrade good components with bad PCB. But you probably know, these days, chips is better way to obtain good transients at high frequencies... they don't have that big PCB or wiring problems, all critical things are in chip
Hope this helps.
Best regards
-boggy
Old 2nd October 2005, 08:51 PM   #7
opp's Avatar
I definitely get some very fine inputs in this forum.
Do you think a chip-amp can bee superior to a class-a? Is Hypex UCD180 a chip amp in this regard – it certainly is small and sounding excellent?
Old 2nd October 2005, 08:59 PM   #8
bogicp's Avatar
I don't know, you must read specs, possibly you may work on some simulations, and build prototypes... then hear it all and decide...
no one in this forum (and world) has same way of thinking, and this is only way to do some better things... look what other works, but think with your head
First thing you can do is some googling for "signal integrity", learn this carefuly, and try to implement some of principles in high speed design in your tweeter amp, and you will hear difference.
Best regards,
-boggy
Old 4th October 2005, 03:25 PM   #9
opp's Avatar
Have been away googling - thought-provoking for me.
Tanks - boggy
Old 4th October 2005, 03:34 PM   #10
bogicp's Avatar
No problem, one thing is in my mind also... what do you think about building not-that-big-power but very FAST tweeter amp, with bandwidth wider than 100kHz, and mount it on tweeter magnet?
Think about phase in broad range amplifiers, can we hear differences?
Best regards,
-boggy
WTB: 2 way active xover MarkHathaway Swap Meet 0 21st September 2008 09:31 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Active xover help! led_zeppelin Solid State 8 28th September 2004 02:14 PM
active xover 5th element Solid State 0 9th March 2003 07:19 PM
ACTIVE XOVER KIERANPHILLIPS Solid State 4 20th August 2001 07:29 PM
Page generated in 0.11260 seconds (78.95% PHP - 21.05% MySQL) with 10 queries
