Old 30th September 2005, 03:54 AM   #1
Ipanema is online now Ipanema  Malaysia
Ipanema's Avatar
Default output impedance
This might not related to audio.
For an amplifier driving a digital pulse at 1Gbps and I want to measure the amplifier output impedance, at what frequency should I measure the output impedance, since impedance varies with frequency and also pulse are consists of many orders of harmonic.
Pls help.
Thanks.
Old 30th September 2005, 05:20 AM   #2
1Gbps = 1 Ghz.
1Giga bits per second............ a bit is just one rise on a square wave, so 1ghz would be the same. You want to test the amp impedance at the frequency you will use it for.
Also 1Gbps = 128MB per second Sounds like a fast signal!
What is it for?
Old 30th September 2005, 06:31 AM   #3
Ipanema's Avatar
1Hz=2bps, so at 1Gbps should I look at 500MHz. Someone tell me that I should at 0.7*bitrate=0.7*1Gbps=700Mhz. I am not sure which one is more accurate. Can you pls clarify?
Thanks.
Old 30th September 2005, 09:03 AM   #4
Data cable is nomally tested higher than the bit rate to ensure the necessary harmonics are carried to accurately reconstruct the data stream.
At 1GbS the highest transition rate would be 500MHz, but to maintain a waveform approaching square you will need the 3rd harmonic so test to 1500MHz.
HTH
Chris
Old 30th September 2005, 09:41 AM   #5
Ipanema's Avatar
For example. if my design is to have 50ohms impedance matching at 1Gbps. From my impedance vs Freq plot, I get 50ohms at 500MHz 30ohms at 1GHz and 10ohms at 1.5GHz. In this case which frequency should I match the output impedance of my amplifier?
Thanks.
Old 30th September 2005, 10:10 AM   #6
darkfenriz's Avatar
Originally posted by Ipanema
1Hz=2bps,
I think it depends on modulation:
return-to-zero, non-return-to-zero, freq. shift key,.......
All of them I'm affraid. Standing waves at any harmonic can be a disaster to digital signal.
What's the amplifier?
Class C power MESFET ? Or small signal?
Old 30th September 2005, 06:35 PM   #7
bscally is offline bscally  United States
Default Impedance...
1) I would take a TDR with a pules faster than 1Ghz and use that.
2) Alternately if you can trigger a single ouput pulse ( or a 10000000 bit pattern) you can look for reflections on the line with an osciliscope. You will need a really good probe though. I use a 8Ghz tek differential probe for looking at those kind of things here.
3) Take an eye pattern and look at the crossing points.
I base this on too much experience with USB 2 (480MHz ) and Sata 1 and 2 - 1.5Gbps and 3Gbps.
Brian
Old 30th September 2005, 06:49 PM   #8
danm send button....
once I have an impediance plot I would match the amp to the plot.
However depending on line length you really need a good match @ 5 times fundamental to get a nice clean edge.
Brian
Old 1st October 2005, 02:25 AM   #9
Banned
You have to be able to pass at least the 3rd and 5th harmonics to get a decent pulse. You have not told us anything about the power levels involved, or how long of a cable this will travel over.
Sometimes you will pre-distort the signal to compensate for anomalies in the output. Such as impedance mismatches.
Jocko
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Output impedance overdrajv Tubes / Valves 8 5th March 2008 05:54 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output Impedance? ble0t Parts 4 19th January 2006 05:45 PM
Low output impedance pre miguel2 Tubes / Valves 13 23rd July 2003 09:51 AM
Page generated in 0.09767 seconds (80.35% PHP - 19.65% MySQL) with 10 queries
