I am a novice at solid based power amp.the only once diy experience is diy a 2x30W classA amp with my uncle in 1992(my uncle work on all parts design and assembly,I work on hand-made pcb board using FeCl3 and a Oil pencil)
I want a simplest design,then I can work out it all by myself.any help are welcome and appreciative. ciao Zang |
#2 |
The simplest design is a single transistor and a couple of resistors...
sound quality may be lacking. try looking to the passdiy website and have a look at the Zen amplifier.
Jesus loves you. |
#3 |
Is there a type of amplifier you prefer? Class A or Class AB, FET or BJT? Output Power? Greetings |
#4 |
hi all,I am sorry for delay.just come back from holiday.
I do not mind the type of amplifier,classA,classC or classAB is all right.I want a simplest amp output 2x30W power to feed coda7. thanks Zang |
#5 |
Be ambicious, Zang...remember, that in this century chinese man will be in the Moon....
#6 |
because the complicated building will make me fun and challenger. the simplest building too. Zang |
#7 |
Account Disabled
you can try one of nelson's designs without the CCS or X-configuration. usually they are nothing more than a mosfet, plus a few transistors.
Sound quality should be good for a small powerred application. If you want to go a little bit louder, you may want to switch into class AB then there are tons of designs to go after, but I like ESP's P3A, in either an EF or quasi output configuration. |
#8 |
ESP's Project 3A is one of the simplest designs you can think of. It is a class AB power amplifier. Resistors R17, R18 and R19 can be left out.
#9 |
I have got a simpler one:
http://sound.westhost.com/project83.htm originally http://www.pha.inecnet.cz/macura/follower_e.html |
#10 | |
Account Disabled
here is my entry. It outputs about 7v peak on 8ohm. R5/R6 are those little 12v xenon lamps - I actually used a peanut tube socket to house those little "tubes". You cannot get simpler than this, :0 You can improve power output with a CCS as load but that messes up the simplicity which appears to be your desire here. |
| Simplest OTL? | leadbelly | Tubes / Valves | 30 | 20th July 2007 10:55 AM |
| simplest sub amp | odysseybmx414 | Solid State | 2 | 28th December 2005 04:24 AM |
| Simplest DAC | audioPT | Digital Source | 1 | 19th April 2003 04:06 AM |
| Looking for the simplest DAC ever... | martioz | Digital Source | 4 | 7th March 2003 03:09 PM |
| Page generated in 0.10169 seconds (76.22% PHP - 23.78% MySQL) with 11 queries |
