#691 |
Dear DR BORA
greetings thank you sir for replying its easy modification i will make it thanks once again for helping me warm regards andrew lebon |
#692 | |
Im confused and have a problem.... how to connect Omni protection Point 7 and 9 in quasi complementary output stage like Legend Stage master MK2 or Quasi NMOS because Point 7 and 9 get full negative rail voltage trough 0,22 OHM resistor any solutions ? |
#693 |
OMNI is for complementary outputs and not for quasicomplementary. Quasi output stage has to be modified.
If you are arguing with an idiot, first make sure that he is not doing the same thing. |
#694 |
#695 |
, this is older version with 24V regulator for relays supply and it wasn’t reliable. Please make a small modification and replace that with simple one transistor stabilizer as on attached schematic. I know PCB isn’t designed for this, but modification is so simple it shouldn’t be a problem to do.
just remove ic 7824 the 2 10uf caps and the jumper to modify pcb for transistor stabilizer put TIP 41 WHERE 7824 was orignally 1 put 24 volt zener diode from base of tip41 to where jumper was taken out to ground 3 put 3.3k 1 watt from collector to base no tracks to be cut PCB has all holes marked on it warm regards andrew lebon |
#696 | |
if interested I can share it for supplier I hope to get update for Omni to protect Quasi output stage |
#697 | |
Top & bottom PCB layout of Techno & Sigma. (Send to my email: Nguyenthecuong1987@gmail dot com) Very thanks for help me!!! |
#698 |
pcb ready for testing
Thanx Dr.Bora
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend |
#699 |
Dear Dr.Bora
I'm completing the purpose of spare parts on the stage driver amplifier Sigma 2SA1407/2SC3601 or 2SA1406/2SC3600 the Sanyo brand. BJT brands like this are hard to find in my town. Is there a replacement series of other brands such as the brand Sanken, Toshiba or other brands. Thank you Good Luck, A.Pramudia |
#700 |
Dear Dr. Bora,
Your e-mail about BJT I've read, your response so quickly. Thanks a lot Good luck, A.Pramudia |
| new diy forum - for the ex-Yugoslavia | Branimir | Everything Else | 0 | 7th November 2005 05:12 PM |
| Hello from Serbia | drax | Introductions | 17 | 5th November 2002 03:28 PM |
| Page generated in 0.11672 seconds (77.84% PHP - 22.16% MySQL) with 11 queries |
