Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 9th November 2009, 08:49 PM   #561
Originally Posted by boraomega View Post
Something is very wrong in your unit Duran!!! How do you explain that you have measured +36,5V across ZD2 (that voltage is OK) but then only +1,2V on the upper wire of the 68k resistor? That is the very same wire!!! Also, you have +13,3V across ZD3 when you should measure -13V there (voltage there should be negative with respect to ground!).
For your info, that unit has been done successfully at least several hundred times up to now… “Viktor1986” is one of them, he can tell you that.
Dear Dr. Bora
First off all I want to present thanks for your quickest kindest reply to you.
I'll check again all voltages and parts once more. Do you have any pre-test procedure of it before the hook up into amp. different then checking the voltage and finding the wrong parts??
Best regards
Old 9th November 2009, 08:51 PM   #562
viktor1986's Avatar
Set the image in high resolution and also photograph plate from the bottom. Thus I do not see almost anything and especially those two 1N4148 diodes which are in parallel with 150nF(yellow blocks).
What I see, you're wrong turn LF353?
Pa mislim sta reci!
Old 9th November 2009, 08:56 PM   #563
Default LF 353 pic.
I'll de solder of them for taking good picture.
Old 9th November 2009, 09:05 PM   #564
viktor1986's Avatar
Upload two photos of high quality, one can see the layout and the other where is the copper.
Pa mislim sta reci!
Old 9th November 2009, 09:17 PM   #565
Default Omni pict.
Here is the other pict.
Thank you very much in advance
Old 9th November 2009, 09:30 PM   #566
Default Omni copper side
Sorry for late because I use two different pc .s one is for pic. editting another for sending.
Best regards
Old 10th November 2009, 06:12 AM   #567
Default Omni Protection
Dear Victor
Could you e-mail me your recent schematics and layouts/part lists etc. for Omni because Ones that are in my hand show me some differances between sch. and layout?
I was already dowloaded it from following link :redesign of leach amp pcb for integrated TO-247 output devices
Best regards
Old 10th November 2009, 08:47 AM   #568
viktor1986's Avatar
It seems all OK in the picture. No you can get a voltage of 13V where there are marked, there must be -13V DC. I have personally made several omni protections and there are no mistakes, except of course if you're somewhere wrong around the value resistor or perhaps a faulty components.
How many volts are relays and that resistance spool? What is the value of the resistor that goes to the entrance LM7824, from +66 V to the input 7824?
There is no need to send you anything because you found on that link.
Pa mislim sta reci!
Old 12th December 2009, 10:21 PM   #569
I’ve done some modifications of appearance and functionality of my WEB site recently, and I also added a link to my BLOG for visitors willing to leave comments about me or my site.
Now entry page is:
:::Borina Amaterska Svastara:::
If you are arguing with an idiot, first make sure that he is not doing the same thing.
Old 13th December 2009, 06:20 AM   #570
destroyer X's Avatar
Send a message via MSN to destroyer X
Default Thank you, there's a lot of pojacala (amplifier) for us.
regards,
Carlos
Dx Blame ST - http://www.youtube.com/watch?v=YrT3ZPU8wIo What Dx Voltage Regulator does:
http://www.youtube.com/watch?v=5rDSMxwcugI
Thread Tools
new diy forum - for the ex-Yugoslavia Branimir Everything Else 0 7th November 2005 05:12 PM
Hello from Serbia drax Introductions 17 5th November 2002 03:28 PM
Page generated in 0.10187602 seconds (75.83% PHP - 24.17% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
