Old 1st November 2009, 01:59 AM   #551
Wasim is offline Wasim  Pakistan
Send a message via MSN to Wasim Send a message via Yahoo to Wasim
Default Xover
Originally Posted by boraomega View Post
Check your E-mail Wasim!
Thank you Sir I got the files
Old 2nd November 2009, 05:33 PM   #552
Hi Sir, I want to know the 100 ohm trim pots are for the frequency set for the bass mid and tweeter? How can we adjust those? Sorry Sir this is my first Xover project
Wasim
Old 2nd November 2009, 05:38 PM   #553
Sorry sir my mistake I was talking about 100k trimpots
Wasim
Old 2nd November 2009, 08:12 PM   #554
No, they are for output level adjustment.
If you are arguing with an idiot, first make sure that he is not doing the same thing.
Old 9th November 2009, 08:56 PM   #555
Default Omni Protection
Dear Dr. Bora
I produce yr. OMNI protection circuit but unfortunately couldn't able to work it yet. led is always lightening and relays never switched on. I was already red following voltages and used resistors as per attached diagram. Relay brand is "SONGLE" ,"SRD-12VDC-SL-C"
Could give me yr. most valuable advices as designer of this circuits?
Thank you very much in advance.
Best regards
Old 9th November 2009, 09:06 PM   #556
Please send us a picture of protection.
Pa mislim sta reci!
Old 9th November 2009, 09:15 PM   #557
one moment pls.
Old 9th November 2009, 09:24 PM   #558
Default Omni Protection Picture
Here is the pict. of it.
Best regards
Old 9th November 2009, 09:29 PM   #559
Do you have a photo in high resolution?
Pa mislim sta reci!
Old 9th November 2009, 09:32 PM   #560
Something is very wrong in your unit Duran!!! How do you explain that you have measured +36,5V across ZD2 (that voltage is OK) but then only +1,2V on the upper wire of the 68k resistor? That is the very same wire!!! Also, you have +13,3V across ZD3 when you should measure -13V there (voltage there should be negative with respect to ground!).
For your info, that unit has been done successfully at least several hundred times up to now… “Viktor1986” is one of them, he can tell you that.
new diy forum - for the ex-Yugoslavia Branimir Everything Else 0 7th November 2005 06:12 PM
Hello from Serbia drax Introductions 17 5th November 2002 04:28 PM
Page generated in 0.10773 seconds (74.72% PHP - 25.28% MySQL) with 11 queries
