Old 25th October 2009, 06:21 PM   #531
I understand my friend, language is the problem for many of us. English is not my native language either!
If you are arguing with an idiot, first make sure that he is not doing the same thing.
Old 25th October 2009, 07:19 PM   #532
radio is offline radio  Macedonia
radio's Avatar
Pozdrav svima! (Hallo All!)
Treba mi sema sa PCB pouzdanog pojacala koje se napaja na Us=±58...60V i za drajvere koristi tanzistore u TO-3 kuciste!?
Unapred HVALA!
Old 25th October 2009, 07:22 PM   #533
black is offline black  Romania
Send a message via ICQ to black Send a message via AIM to black Send a message via MSN to black Send a message via Yahoo to black
you can buy kit mk2 master legend? Sir Dr. Bora
Old 25th October 2009, 07:58 PM   #534
I think I understand but answer is NO for now. My designs in a KIT-form are still not available.
Old 25th October 2009, 08:53 PM   #535
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
Originally Posted by black View Post
I'm sorry but using Google Translator can not translate well sorry
search
@black :
Aren't you Romanian ???
If you are you can PM and i will translate as i was born and raised in Arad and moved out to Canada in my early teens
Old 26th October 2009, 03:06 AM   #536
radio's Avatar
Hi everyone!
Thebes me reliable audio amplifiers (scheme and PCB), which will be powered with the Us=± 55t... 60V. Output transistors to be in the TO-3 housing (as MJ15003/MJ15004, etc..)
Thank you,
Old 26th October 2009, 03:12 AM   #537
radio's Avatar
Lightbulb Scheme and PCB!?
Hi everyone!
Thebes me reliable audio amplifiers (scheme and PCB), which will be powered with the Us= ±55...60V. Output transistors to be in the TO-3 housing (as MJ15003/MJ15004, etc..)
Thank you,
Old 26th October 2009, 04:41 AM   #538
radio's Avatar
Default PCB for Blaster Amplifier!
Thebes me reliable PCB for Blaster Audio Amplifier!
Thank you!
Old 26th October 2009, 02:15 PM   #539
@radio
I understand what you are asking for and this amp is best suited for your needs. It was designed for a guitar amp, but it is useable as any other amp. Very reliable and robust. Only minus is - I don't have PCB design any more because I lost it. It was drawn on paper (no PC-s back then! ... end of '70-es) and I can't find that paper any more! Of course, now it has more modern components available today.
Old 27th October 2009, 08:20 AM   #540
Wasim is offline Wasim  Pakistan
Send a message via MSN to Wasim Send a message via Yahoo to Wasim
Default Techno
Originally Posted by boraomega View Post
Wasim, disconnect preamp or any source of signal, short your PA inputs, adjust BIAS and DC in the output, connect speaker and listen. If there is hum from the speaker it is probably related to your wiring and grounding of amps PCB-s and PSU. Some really minor noise-hiss from tweeters with your ear very close to that driver is possible and acceptable.
Hi Dear Sir,
Hum problem has been resolved. Now Techno is working very well.
new diy forum - for the ex-Yugoslavia Branimir Everything Else 0 7th November 2005 06:12 PM
Hello from Serbia drax Introductions 17 5th November 2002 04:28 PM
Page generated in 0.10966 seconds (75.48% PHP - 24.52% MySQL) with 11 queries
