Old 16th August 2012, 08:51 AM   #741
engel dela pena is offline engel dela pena  Philippines
sir bora,
what about the diode joselito put out to rail in reverse polarity,do you find this a good practice?
Old 16th August 2012, 09:13 AM   #742
alex mm is offline alex mm  Romania
alex mm's Avatar
..... you have wrong direction on those diodes ,they must be reversed
Old 16th August 2012, 11:17 AM   #743
alex,
what does he mean by this?
Dear all,
The amplifier is working good now, clear and very strong. I added 2 more pair of cap at PSU total now is 100,000uf per rail. In addition, I installed 6amps 1000 volts diodes at the output to rails in reverse polarity to avoid loading the amp from speaker
Old 16th August 2012, 12:32 PM   #744
R.I.P.
He means that the diodes do not pass Power Supply rail current directly to Zero Volts.
Reverse polarity requires the diodes to block current flow.
regards Andrew T.
Old 16th August 2012, 12:42 PM   #745
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by engel dela pena View Post
alex,
Dear all,
Engel,
the diodes are there to protect the collector emitter of the output transistors from back emf of the speakers.....these diodes return the energy back to the psu rails....if those diodes were not there, these back emf have nowhere to go but thru the output trannies....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 16th August 2012, 12:58 PM   #746
alex mm's Avatar
.......I mean this
Old 22nd February 2013, 05:09 AM   #747
Wasim is offline Wasim  Pakistan
Send a message via MSN to Wasim Send a message via Yahoo to Wasim
what is the address of dr bora's website ? this link is not working Abshost.net
Old 22nd February 2013, 05:16 AM   #748
naf is offline naf  Indonesia
:::Borina Amaterska Svastara:::
Old 27th February 2013, 01:08 PM   #749
viktor1986 is offline viktor1986  Serbia
Today is the opening of the new forum on boraomega web page.
Pa mislim sta reci!
Ce sa spun!
Old 14th September 2013, 07:49 PM   #750
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
ome-sigma amplifier
HomeMadeAudioProject: OME SIGMA 2 - YouTube
OME SIGMA (prvi put u ku?i) - YouTube
OME Sigma - HomeMadeAudioProject - YouTube
Chop your own wood and it will warm you twice
new diy forum - for the ex-Yugoslavia Branimir Everything Else 0 7th November 2005 05:12 PM
Hello from Serbia drax Introductions 17 5th November 2002 03:28 PM
