PCB or kit for power amplifier advise NEEDED
Old 26th September 2005, 01:38 PM   #1
rmihai is offline rmihai  Canada
Default PCB or kit for power amplifier advise NEEDED
I have a fairly good idea of what kind of design I am looking for, just I don't know if someone offers a kit or at least a PCB board for this. Please let me know.
- min 175W in 8 ohms
- input stage: dual mono JFETs cascoded with MOSFET
- second stage: two paralleled JFETs cascoded with MOSFETs
- driver circuit fed from regulators using dual low-noise JFETs, Cascoded with MOSFETs for the input, and MOSFETs in the driver and output stage
- separate power supplies for the driver stage and the output stage
I am planning to use Toshiba C3281/A1302 outputs, Toshiba jfets, Hitachi mosfets, Caddock resistors, HEXFRED and/or FRED diodes, Elna capacitors.
So, is there any design/kit/pcb that you are aware of that will meet my needs?
Thanks a lot.
Old 26th September 2005, 09:19 PM   #2
viktor1986 is offline viktor1986  Serbia
Wink Amplifier
Contact www.bas.abshost.net
You will find his E-mail and ask him.
Pa mislim sta reci!
Ce sa spun!
Old 28th September 2005, 10:59 AM   #3
Any other ideas?
Old 28th September 2005, 12:48 PM   #4
roger-k is offline roger-k  Norway
What about this one:
http://sound.westhost.com/project101.htm
Roger
Old 28th September 2005, 04:33 PM   #5
I am seriuosly considering Rod Elliot's Project 101.
The problem is that I do not know its topology. Does it has dual mono JFETs cascoded with MOSFET in the input stage? Does it has two paralleled JFETs cascoded with MOSFETs in the second stage? The driver circuit is fed from regulators using dual low-noise JFETs, Cascoded with MOSFETs for the input, and MOSFETs in the driver and output stage?
Does it has separate power supplies for the driver stage and the output stage?
I do not know the answer to all these questions. Maybe someone who built already the Project101 can clarify for me.
Thank you once again.
Old 28th September 2005, 07:41 PM   #6
carlmart is offline carlmart  Brazil
What do you mean you don't know the topology of Project 101? The circuit is there. It's all bipolar with a MOSFET output.
Carlos
Old 28th September 2005, 08:22 PM   #7
Why don't send a mail to Rod Elliot and ask him these question.
Roger
Old 29th September 2005, 12:38 AM   #8
amplifierguru is offline amplifierguru
Account Disabled
Hi rmihai,
You seem to require a very specific topology, why is that? You have a preconceived idea of what will perform for you which I doubt you'll find.
What about a very different topology - comp cascoded BJT (or modifiable to FET) diff'l inputs, comp emitter follower drivers followed by 4 pair of common source comp MOSFETs for 250W at typ 0.003% THD.
It will be available as a kit,details on my website when it's up - tomorrow!
Greg
PCB or kit for power amplifier advise NEEDEDHide this!Advertise here!
Changing bridge. Advise needed Fidelity Audio Power Supplies 10 7th December 2010 11:11 AM
Help! Speaker design advise needed beeroclock Full Range 0 30th March 2007 11:58 AM
Wildlife Electronic Caller, advise needed jringels Class D 5 13th April 2006 10:14 PM
Simple Cap-Coupled CF Advise Needed dr._sleep Tubes / Valves 6 10th August 2005 06:50 PM
Box Construction .. advise needed fast kat Car Audio 6 13th April 2004 05:14 AM
