Hello all,
I recently bought a Yamaha A-760 stereo amplifier in a second hand shop, it was cheap and thought I'd gine it a go to get it fully working. After a bit of fiddling I got it working, all that's wrong now is that the panel lighis do not work. Does anyone know fo a schematic for this amp or know anything about it. Your help would be appreciated. Cheers CB |
#2 |
#3 |
It's possible the lights are wired in series, so if one bulb has blown then none of them will light. Do a simple continuity check over each bulb.
#4 |
That's very likely the case. My CA410 is wired in series.
#5 |
Hi Dynsdale,
The lamps may be burned out - that's normal for this age. Did you check if there is voltage across them? Sometimes Yamaha will use the lamp to perform another function. Like the muting circuit in some of their receivers. -Chris |
#6 |
Thanks to all, sorry about the late reply, been out the house.
I will give your suggestions a try. Many thanks, CB |
| Yamaha AX-930 | jleaman | Analogue Source | 6 | 21st November 2010 12:43 PM |
| Yamaha cdx 900 | stex | Digital Source | 4 | 23rd January 2010 12:44 PM |
| Yamaha RX-777 | quasi | Solid State | 4 | 15th November 2007 01:58 PM |
| Yamaha A-550 | angel | Solid State | 4 | 18th January 2006 02:22 AM |
| Yamaha CDX-490 | newbie123 | Digital Source | 1 | 3rd December 2005 04:31 PM |
| Page generated in 0.08479 seconds (76.06% PHP - 23.94% MySQL) with 10 queries |
