Preamp concept - Page 3 - diyAudio
Old 24th September 2005, 04:04 PM   #21
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, PMA,
This one seems not coming from you. Lack of PMA characteristic
You dont use differential or CCS for the first stage?
Is this better than your openloop I/V converter?
Hi, all,
I have a question about Diamond buffer used as power amp output stage. From some examples, I see 2 kind of DB used for power amp. One is CCS feeding (like the one here and also Walt Jung), the other is only R loading, like this one I attach. It comes from a respectable sounding Marantz. Using 7W 8K2 plain resistor, even without bootstrapping.
What is the pro/con between using CCS and R for feeding diamond buffer?
2nd. Is it necessary to put Capacitance between upper and lower diamond buffer? The Marantz has 2 x 10uF cap around DB, while Walt Jung uses none. Again, what is the pro/con between these 2?
Old 24th September 2005, 04:26 PM   #22
anli is offline anli  Russian Federation
Well, I must mention, cited preamp was inspired by Kingwa's amps (audio-gd.com).
Old 24th September 2005, 05:46 PM   #23
PMA is offline PMA  Europe
PMA's Avatar
By the time I have built (not only simulated) the amp shown here in http://www.diyaudio.com/forums/showt...220#post730220
The amp is pretty fast, F(-3dB) = 3MHz. It does not need the output RC correction as shown. It is stable, drives pure 1500pF load without problem, with square signal tr = 10 ns at the input. Step response is without overshoot, with 1500pF load the overshoot is about 20%. Sine wave of 3MHz is pure at the output, undistorted. Output impedance is low, about 4 Ohm. It drives even 50 Ohm load. I will give it a chance and will make a preamp based on this circuit. Simplicity makes sense.
Old 24th September 2005, 05:52 PM   #24
PMA's Avatar
Originally posted by lumanauw
Hi, PMA,
I wanted to build quite fast and very stable stuff for now, for this reason I did not use global feedback, CCSs, mirrors etc. I am interested in sound result of this approach. I kept class A. The circuit has quite a lot of gain if needed, this is set by resistors between emitters of the input differential stage. DC is set by resistor between collector of the 2nd transistor and ground.
Old 24th September 2005, 06:27 PM   #25
PMA's Avatar
David,
as you know, I also built a diamond buffer based power amp with R feeding, see http://www.pha.inecnet.cz/macura/next.htm. Though CCS should be superior due to maintaining the constant current even for large output swings, the results do not seem to be that different. The capacitor between bases in my circuit reduces distortion and helps the transition to class AB, if needed.
Old 24th September 2005, 06:31 PM   #26
Originally posted by PMA ... Simplicity makes sense.
I don't like plenty of parts too, capacitors especially But - what is your opinion about thermal distortions importance (I mean active parts outside global NFB loop, as in your case, as you have not global NFB )?
Old 24th September 2005, 06:34 PM   #27
PMA's Avatar
I made a mistake here, I was speaking about 15 000 pF load. Verified also for 47 000 pF, no problem.
Old 24th September 2005, 06:36 PM   #28
PMA's Avatar
I know what you are speaking about and I have read those articles. Frankly speaking - I do not know.
Old 24th September 2005, 06:44 PM   #29
I have read an artcicle by russian author also, unfortunately, in Russian only:
http://www.aml.nm.ru/reasons.htm
Old 24th September 2005, 06:46 PM   #30
PMA's Avatar
Thank you Andrej, russian is no problem for me.
Help with a concept the joz Subwoofers 14 26th February 2009 07:22 AM
FS: Gain Concept No.X kirc Swap Meet 0 7th December 2007 09:40 AM
AV OB concept Geoff H Multi-Way 2 4th February 2007 06:31 PM
Another ESL Concept just.sounds Planars & Exotics 2 15th February 2006 10:35 AM
New speaker concept SY Multi-Way 3 15th September 2004 02:41 PM
Copyright 1999-2017 diyAudio
