Old 24th September 2005, 02:40 PM   #11
PMA is offline PMA  Europe
PMA's Avatar
Originally posted by darkfenriz
Applied along the section of voltage gain of 1....?
On this RC there is a buffer error voltage drop, dividing by RC impedance you get parasitic error current drawn from VAS.
I think you are trying to be mysterious about the point of this arrangement...
As you know, the followers have 100% voltage feedback. Do you think they are unconditionally stable?
Old 24th September 2005, 02:40 PM   #12
anli is offline anli  Russian Federation
Pavel,
No, I don't
There are no resistance values on the schematics. I have suggested output emiter resistors are about 10-50 ohm. In such case to move out stage to class A some emiter resitors are necessary for pre-out pair too. Where is my mistake? Or - what is your concept in words?
Old 24th September 2005, 02:47 PM   #13
PMA's Avatar
Andrej,
you are right. There are no values, which makes the case more interesting. The output emitter resistors are only 2.7 Ohms. Bias current is a game of Vbe voltages and thermal coupling.
Old 24th September 2005, 03:00 PM   #14
darkfenriz's Avatar
With emitter resistors of both 'drivres' and output stage you could add some local modulation or error correction or feedback or whatever one would call it.
Maybe you would be interested in my use of diamond buffer with modulated current sources (error correction).???
Perfect buffer for unity gain preamp, headphone class A amplifier or filters.
Needs some adjustment of bias and offset: 321R/339R are pots.
What do you think?
schematic:
Old 24th September 2005, 03:02 PM   #15
darkfenriz's Avatar
Forgot to add:
for low power speaker amp/ headphone amp one could take advantage of sweeping bias point.
Old 24th September 2005, 03:26 PM   #16
PMA's Avatar
You mean to use it as an output stage? The circuit I have shown can have a voltage gain up to 40 dB without problems.
Old 24th September 2005, 03:28 PM   #17
darkfenriz's Avatar
yes
Old 24th September 2005, 03:51 PM   #18
As for preamp (before output buffer) concept, I have selected (and am listening now) this topology:
http://gaydenko.com/preamp/final.jpg
Old 24th September 2005, 03:53 PM   #19
PMA's Avatar
Andrej - how does it sound and how does it measure?
Old 24th September 2005, 04:03 PM   #20
Pavel,
I have no experience in listening to nice amps. In such conditions it is the best
This is card's own spectrum:
http://gaydenko.com/preamp/card-own-4KHz-500mV.png
This is the preamp bridge-half spectrum:
http://gaydenko.com/preamp/un-4KHz-500mV.png
Last one was measured for prototype. In real preamp input fets were selected, and 2d harmonic is about -92db. All others are below my card resolution.
Help with a concept the joz Subwoofers 14 26th February 2009 07:22 AM
FS: Gain Concept No.X kirc Swap Meet 0 7th December 2007 09:40 AM
AV OB concept Geoff H Multi-Way 2 4th February 2007 06:31 PM
Another ESL Concept just.sounds Planars & Exotics 2 15th February 2006 10:35 AM
New speaker concept SY Multi-Way 3 15th September 2004 02:41 PM
Copyright ©1999-2013 diyAudio
