#101 |
Sorry, you are right. Small capacitors are 100nF ceramics. Electrolytes are 1000 uF (see photo of the preamp).
Pot is 5k or 10k. Do not go higher than 10k. |
#102 |
Thank you
#103 |
MaxS,
I have made my audiopage working again .But I have to apologize to the readers - sometimes I am really not able to respond, being pretty engaged in my professional projects ... |
#104 |
Oh one more thing what's the connection for little pots. Which lead is connected to the regulation (trim lead)?
and does it matter if 1 or 3 is first? |
#105 |
The small trimpots (R9 and R25, or R2 in "values.gif") are used for fine setting of gain - to match gain of both channels. They work as variable resistors, you do not have to care how to connect the middle pin - left or right end, does not matter.
#106 |
I understand that the value that has to be set by these vresistors is 20 mA as shown in the schematic?
#107 |
I wonder why have you put R42 and R38 together instead of one resistor?
I bet it's because U had such values in stock .Or is this value to be realy precise 1K97. I thought about putting there 1K91 ( I can get this value) and it will be within 1% tolerance. Am I clever
#108 |
These resistors set DC at Q3 collector. It is easier to do it by 2 in series than by 1, as the value has to be set quite precisely.
#109 |
Pavel
I have another question> What if I changed in-capacitors and out-cap value. e.g I would like to put there black gates N but there are no such values. And does the in cap is not as important as out cap. According to the picture you have put odinary mkp (wima?)cap at the input. Wouldn't it be better to put pot instead of one of resistors for DC setting? |
#110 |
If you change these values, make them higher, never lower. The choice of cap types is up to you.
| Help with a concept | the joz | Subwoofers | 14 | 26th February 2009 07:22 AM |
| FS: Gain Concept No.X | kirc | Swap Meet | 0 | 7th December 2007 09:40 AM |
| AV OB concept | Geoff H | Multi-Way | 2 | 4th February 2007 06:31 PM |
| Another ESL Concept | just.sounds | Planars & Exotics | 2 | 15th February 2006 10:35 AM |
| New speaker concept | SY | Multi-Way | 3 | 15th September 2004 02:41 PM |
