Old 21st September 2005, 08:26 PM   #1
Sander is offline Sander  Netherlands
Default Rod Elliot's P3A considirations
Hello,
Currently I'm building a Rod Elliot P3a, from Rods website sound.westhost.com. My problem is that I don't have enough knowledge about capacitors to chose the right one for its purpuse.
There are many different types of capacitors such as, elctrolytic, MKP, cermamic, etc. Could you please help me deciding wich type I should use at which place? I would like to know the main purposes en performance areas of the different types. Thanks in advance!
Old 21st September 2005, 08:46 PM   #2
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
I'm pretty sure that Rod will send you a parts list along with the PCBs for the project
\Jens
Old 21st September 2005, 09:09 PM   #3
apassgear's Avatar
Some suggestions for starts:
C1: MKP or some would like Black Gate lytics
pf values: Polyestirene or MKP, for lower values you can also use Silver Mica.
nf values: MKP or Mylar films.
uf values (other than C1) use electolytics
In any case check the footprint of your selections to see if they match your PCB.
Old 22nd September 2005, 03:16 AM   #4
still4given's Avatar
Looks like C1 is polarized, doesn't that mean it has to be an electrolytic?
Oops, for the BOM
"C1 may be a standard electrolytic capacitor if desired. If a polarised electro is used for C1, the polarity is not shown on the overlay, but is clearly indicated on the overlay drawing.
Blessings Terry
Old 22nd September 2005, 07:12 AM   #5
C1 should be a non polar electrolytic or back to back polarised of double the capacitance value.
It would be far better to use a film cap here instead but MKP will be much larger and cost considerably more.
The builder decides!!!
Ceramic would never be used in the audio stages due to variable capacitance as the voltage varies. However they are unbeatable in decoupling of the hi frequency rubbish on the PSU etc where they see an almost constant (DC) voltage.
The film type usually perform better than any of the electros even black gate. Some film are better than others. Polypropylene, polystyrene and teflon are of the highest quality,
Polyethylene and polycarbonate are the next level down. Then there are a few others.
Try a search for a much more full report on capacitor quality
regards Andrew T.
Old 22nd September 2005, 08:16 AM   #6
Account Disabled
C1 simply isn't necessary as long as there's no DC coming from upstream! It's a case of best C is no C.
Greg
Old 22nd September 2005, 12:18 PM   #7
Here is my P3A BOM with part numbers from DigiKey.
I haven't built mine yet, but soon ...
Old 22nd September 2005, 03:43 PM   #8
Hi Amplifier Guru,
the dc blocking cap C1 also stops bias from one amp interacting with the bias from another if more than on power amp is connected to the same source.
regards Andrew T.
Old 22nd September 2005, 04:26 PM   #9
rushi is offline rushi  Finland
Sander: Do _NOT_ use electrolytic as a C1. Use Polypropylene (Aydyn-Cap or similar) or better, Paper-In-Oil caps. It doesn't have to be 4,7µF, 1...2,2µF works fine. It won't fit on PCB, but who cares?
All electrolytics should (must, imo) be low-ESR types, Black Gate or something (OS-CON more preferably).
Mylar, MKP (Polypropylene), Silver-Mica or polystyrene for smaller ones.
That's how I would do it.
Old 22nd September 2005, 05:01 PM   #10
paulb is offline paulb  Canada
You can use a non-polarized electrolytic for C1. Or polarized. Disregard most of the hype about must-not-use, 99.9% of us can't hear the difference. Those that claim they can probably can't.
However, the output transistors can make a big difference.
DOZ - Death of ZEN amp from Rod Elliot hifimaker Pass Labs 26 6th April 2012 05:09 PM
Rod Elliot P37? roger-k Solid State 21 7th October 2006 07:37 PM
Rod Elliot's new Mosfet Amp AKSA Forum Problems 1 20th February 2004 07:42 AM
Another new Rod Elliot amp! p3B! Mattyo5 Solid State 20 27th January 2004 11:45 AM
Elliot's 60W AB amp mrpibb Solid State 2 29th April 2001 09:51 PM
Page generated in 0.09933 seconds (77.72% PHP - 22.28% MySQL) with 11 queries
