Hello,first of all,sorry for my bad english...
I wonder why is so spread the use of the potenciometers for control the audio signal and there is almost no developement for other systems to control the signal level in hifi or high end... I mean that a audio signal goes into a pot with all the problems that it implies :bad contact between slider and carbon track,bad dinamic range (comparing to others devices),signal degradation in highs levels of attenuation,parasite capacity etc threre are pot s like the DACT that have great performance but is in the same way and the intrinsic limitations are the same so I ask why not to use with the potenciometer devices with more performance (noise,bandwith,dinamic range etc) like a good opamp (or discrete) in a certain configuration that the audio is not adverse affected by the pot?..... In passive the best look like the secondary stepped transformer way.... it isnt? Best regard |
#2 |
I think I understand your question, but let me ask you:
How exactly do you propose controling the volume with opamps instead of potentiometers? Do you have a schematic (or could you explain it in more detail)? |
#3 |
Pots are not that bad. Unless you mis-use them of course!. Transformers have an entire host of possible problems, they are less perfect.
-Chris |
#4 | |
#5 | |||
Previously: Kuei Yang Wang
Konnichiwa,
(hint, if you use the resistor to change both AC and an overlaid DC voltage you can use the DC to drive a servo which makes sure the DC attenuation follows a preset ratio, but adding DC you now need blocking capacitors which a normal potentiometer does without, so most of the time you merely swap one problem for another) Quote:
Sayonara |
| FS: Power Chip OpAmps and other OpAmps & D to A Converter | dtm1962 | Swap Meet | 4 | 12th January 2006 10:07 PM |
| F.S.: Pots | Cobra2 | Swap Meet | 9 | 13th December 2005 08:08 PM |
| FS: heatsinks and OPA549 +opamps/digital pots | needtubes | Swap Meet | 0 | 8th September 2004 07:26 PM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 04:33 AM |
| Pots | Vivek | Parts | 12 | 18th May 2002 07:50 AM |
| Page generated in 0.08354 seconds (75.81% PHP - 24.19% MySQL) with 10 queries |
